FIRST thing, I need a subwoofer for Denon 1400h
Discussion in 'What Speakers Should I Buy?' started by cls75, Oct 14, 2017.
  1. cls75
    cls75
    Oct 14, 2017
    12
    4
    Arad
    Hello to everyone,
    I am new here.
    I just bought a Denon AVR-X1400H. This will replace my old all-in-one JVC home theater system.
    I will keep for a few months my old satellite speakers, but I need to buy an active subwoofer (the old one is passive). One to mach my next loudspeakers.
    I plan to buy 5 speakers from Indiana Line Nota series. Or something similar.
    But first, I need a subwoofer. I intend to spend no more than 350 Euros for the sub.
    What do you say? Please share your experience.
  2. gibbsy
    gibbsy
    May 17, 2007
    14,077
    3
    Cwm Cynon, De Cymru
    +7,902
    Be careful using old speakers. If they are below 4 ohm, if should tell you on the speaker info label, that could prove damaging to the receiver. Otherwise have a look at BK or SVS subs to suit your budget.
  3. cls75
    cls75
    Oct 14, 2017
    12
    4
    Arad
    It is OK, my old speakers are labeled 6 ohm.
    Unfortunately BK are not for sale in my country. I really wish a SVS sub but is over my budget, they start from 600 Euros (svs sb-100).
    Any other brands I should look for?
  4. gibbsy
    gibbsy
    May 17, 2007
    14,077
    3
    Cwm Cynon, De Cymru
    +7,902
    It's difficult to recommend any subs because of your country's pricing. Tell us what's available and go from there. Glad your speakers will be fine.
  5. cls75
    cls75
    Oct 14, 2017
    12
    4
    Arad
    Thank you.
    Almost every important brand is available but not always prices are the same as in western countries.
    I have to make my decision between:
    Klipsch
    Wharfdale
    Jamo
    Audio Pro Addon
    Acoustic Energy
    Polk
    Monitor audio
    Taga harmony
    Dynavoice Magic
    Indiana Line Basso
    Boston Acoustic
    Emotiva BasX
    JBL
    Cambridge Audio
    Activ Apart
    KEF
    Focal
    All brands above, not to mention Sony, Yamaha and Pioneer, have models priced around 350 Euros. I am not familiar with all that brands and I appreciate your advice.
  6. gibbsy
    gibbsy
    May 17, 2007
    14,077
    3
    Cwm Cynon, De Cymru
    +7,902
    That's a big list. What I suggest is that you find one that is closest in output to the passive you already have as all subs basically do the same job and with keeping your current speakers there is little point in spending too much. I would look closer at Klipsch, Cambridge Audio and Wharfdale.
  7. cls75
    cls75
    Oct 14, 2017
    12
    4
    Arad
    Thanks.
    I will keep in mind.
    I was also advised about Emotiva subs and I might buy one of the models.
