first they work then they don't!
Discussion in 'Movie Forum' started by bertha, Dec 24, 2001.
  1. bertha
    bertha
    Oct 25, 2001
    1,305
    +89
    I have 2 films in my collection that used to play fine Galaxy Quest (R1) & The Road to Eldorado (R1) - the kids films you understand..now they don't my Wharfey just freezes up when I put them in I've tried all sorts of combinations to try & get them to work but no joy..they work fine on my mates Sony..I've been thinking of upgrading anyway but is there any reason why they should decide not to work? I've given them a clean as well but no good..Any shared experiences welcome...cheers
  2. BadAss
    BadAss
    Feb 2, 2001
    2,967
    England
    +182
    dirty heads or dirty discs
  3. European
    European
    "dirty heads"
    ...ahh... dirty heads...?... (we ain't talkin' VCRs, y'know!)...
    . . . :confused: . . .
  4. bertha
    bertha
    Oct 25, 2001
    1,305
    +89
    the discs have been cleaned and the dvd uses a laser I'm sure (it's a little light bulb that blinks) - so I'm still nun the wiser but cheers for the suggestion;)
    Anyone else any suggestions or do you think this could be a massive conspiracy to make everyone rebuy their films after a while...or is it just my players just not that great...?
    cheers
  5. Reiner
    Reiner
    Jul 16, 2000
    3,315
    61
    Germany
    +13
    I guess dirty head here means dirty lens through which the laser focuses on the disc.
    You can clean it with a cotton-bud (Q-tip) and some isopropanol, but be sure not to scratch it, they are usually made from plastic.
    You may try a special disc to clean the lens first if you do not want to open the player, should be available from your dealer or department stores.
  6. swarrans
    swarrans
    Dec 21, 2001
    404
    16
    Kent, UK
    Does anyone have any experience of using laser lens cleaning disks? I've seen them advertised for about £10, but I kinda struggle with how a non-contact/fluid cleaning system would actually work on a lens - I'm prepared to be dazzled by your technical explanation however, or failing that some practical experience of it's effectiveness!
    I've got a rather old DVD player that seems to be getting a bit picky - freezing, long layer changing etc and if a £10 disk would help I'll try it.
    Failing that it might be a good excuse to make that upgrade I've been considering!
    Simon
  7. bertha
    bertha
    Oct 25, 2001
    1,305
    +89
    thanks for that...I'd be interested to hear if anyone has successfully used one of the cleanser discs too..I'm not too confident at technical stuff....
    cheer for now
  8. kenfowler3966
    kenfowler3966
    Jul 23, 2001
    844
    leeds UK
    +14
    All a cd/dvd cleaner disc is, is a normal disc with some info on so the head tracks across it, with a stuck on fine brush to clean the head as it spins over it.
    Nothing hi teck at all, but I think a carefully applied cotton bud with correct cleaner on is a safer solution to a dirty head, with no risk of scratching or mechanical damage involved. Unfortunately this probably means opening the case,mine for example has a seal across the joint with "warranty void if opened" written on it.
