First subwoofer build - advice needed!
Dubtings
My first post on the forums but i've been browsing frequently and decided to try and get advice from you guys.
I have a little bedroom setup at uni (for music, not movies) with 2 100W RMS floorstanders (completely forgot the model and im not up there at the moment). Theyre 3-way with a 12" bass driver and give very good mid range but arn't cutting it for low frequencies.
I seem to remember the graph on them shows the level seriously dropping at around 60hz.
Anyway ive been looking for an active sub for a while to go with this, especially since ill be moving into a much bigger room next year.
My budget isnt much being a student .. roughly £200-300
I wondered whether it is worth me building it for this price range? what drivers would you advise?
As i said it will be quite a big room so after having a little look into designs (Audio Innovation - by Dan Marx www.danmarx.org) i decided i should probably go for a bass reflex design..?
Two problems are that i wouldn't be amazing at building the box, (my brother has been doing a carpentry course for a while now thou) and i have no idea about calculating the size of the box/port so need help in this respect!
Thanks,
Jake
Member 639844
Former Advertiser
Hi, we can help with calculations, but in all honesty I dont think you could build something better than one of the BK offerings within your budget.
Have you had a look at those?
Member 639844
Former Advertiser
I'd agree, but reckon £500 is the baseline figure, given the existence of the Monolith. If you have £300 to spend then look at the XLS-200, or 300pr if you can push to it.
🎬 Across the Spider-Verse, Fast X, Covenant, Sisu, Changeling 4K, Lighthouse 4K, Quantumania 4K & TV
Back
