C
Cas141
The screen will be a roller blind- The projector will be used with a computer to play flight sims and occasional DVD films.
At these distances is
1. screendoor and rainbow effect in DLP evident/accentuated/less so??
2. SVGA more acceptable or less - I would really like XGA. Is the latter a must?
Lastly where in Hants / Dorset can I get demos- Not as easy as you think!!
