First PC Build
YanYang Chen
I am currently planning my first PC build. My list of components are as follows.
  • i5 4670
  • Asus Z87-Pro
  • MSI Twinfrozr GTX 770 2GB
  • 2x4GB 1600MHz Cosair Vegence low profile RAM
  • NZXT 550W 80+ Gold (92%)
  • NZXT H440
  • Kingston HyperX 120GB 450mb/s W/R
  • Windows 8 OEM 64bit
While I am fairly sure this list of components should work together okay, I would like to check with some more experienced people. I would also like to ask whether there are any other things I should buy along to help with the build. At the moment I have a large amount of cable ties and an anti-static mat, but I'm not sure as to what else could be useful.
Finally, as a closing thought, since this costs a fair bit, I currently have no budget for a monitor, so if you have any recommendations on a decent cheap monitor, I would appreciate it, since my current lot is a 28" with a resolution like Diablo II.
