First PC Build - Feedback Wanted
So I'm planning on building my first PC, I've got some knowledge of replacing PC parts but never a full build.
My intention was to build an all purpose rig that can handle gaming (CoD 4, Diablo 3 etc.) and get me through the next few years as I don't think I'll be having a lot of money to spend on upgrading a PC at Uni.
I was looking to spend around £500 so I could buy the parts straight away but what I've got comes to just over £600 currently so I'll be looking to buy some now then the rest when I get paid.
List of prospective parts:
CPU: Intel E8400 £128.21 Scan
GFX: Inno3D Nvidia GeForce GTX 260 FreezerX2 £129.99 Ebuyer
HDD: 500Gb Seagate Barracuda £43.22 Scan
PSU: OCZ ModXStream Pro 600W Modular £70.84 CCL
Case: Cooler Master 690 £63.86 MicroDirect
MoBo: Gigabyte GA-EP45-UD3R £102.06 Ebuyer
RAM: OCZ 4GB ddr2 1066 Platinum Memory CL5 £44.13 Ebuyer
DVD: Samsung SH-D163B-BEB 48x CD 16x DVD £12.18 Scan
Wireless: D-Link AirPlus-G DWL-G510 £16.33 Ebuyer
(PSU & Case prices include shipping)
Would really like some feedback on the parts chosen and whether there's any alternatives I could be looking at (cheaper ones if possible :D )
Cheers guys!
EndlessWaves
If you want to keep it for a few years then you may regret going for a dual-core, the E8400 is technically the fastest currently but it doesn't make much difference at the higher normal resolutions because most games are GPU-limited and in three or four years time when things will be CPU limited games may be using quad-cores. But then they may not and the E8400 will be better.
You can probably knock £30 off the cost off the power supply and £20 off the cost of the motherboard also.
Have managed to find a couple sites cheaper than what is listed above, bringing the total down about £20 altogether.
Are there any quad cores in a similar price range that you would recommend I look into?
