First Home Theater, 5.1.2 or 5.1.4? Looking for feedback on parts & sketches
Looking for advice & suggestions for our first dedicated home theater room for me and my SO. We have a big room in our basement which we are planning to have divided in half by a wall, and where the other half will be the theater room. This gives the following dimensions for the room:
3.31 x 4.5m (10.8 x 17.7ft) which is roughly 15m²(161ft²) with the 4.5m direction being flexible to be lengthened a bit… realistically by 30cm(1ft) but more if absolutely needed. Ceiling height is 211cm (7ft).
Budget: 6000€ (stretch budget 7000€~). LG Oled77c1 already purchased so -3000€ on budget, the rest is for speakers & receiver.
Use case: 80% movies, 19% gaming(mostly PC but some PS4 and perhaps some retro consoles), 1% music
Current sketches how I have planned so far below. Please note that nothing is set in stone (except the TV which is already bought) so things can be moved around etc. Also I will be adding carpet & fixing acoustics afterwards.
So here is my suggested list to buy:
Price: package: 1300€. With 2x BRA1 atmos 1700€
Atmos/height speaker options (either 1 or 2 pairs depending on question #1):
Price: XTZ 400€ pair. Triangle 450€ pair(but cheaper if bought in above package)
Subwoofer:
Price: 700-750€ (700 if I decide to go with a warranty returned one, which still are pretty much brand new and same 5y warranty)
Main speakers: there are soooo many brands out there, and not all available for test listening but I'm somewhat confident in my choice of the boreas after reading and researching.
Atmos: I'm not sure regarding the atmos speakers, I'm leaning more to the XTZ ones due they have an excellent mounting mechanism(& angles. See this image how flexible it is ) for the ceiling (the boreas can only be properly fastened to walls), they are somewhat smaller & lighter that might work better with my already low ceiling and they include the mounts. Also if I understand correctly atmos speakers do not need to be timbre matched to the rest.
For 5.1.2 :
For 5.1.4 :
- Denon AVR-X3700H (1450€)
Kinda expensive with current pricing but looks interesting nevertheless, and basically is the only model in this category so really no questions about this product.
Any feedback would be greatly appreciated!
General questions
- First question is if my room is big enough for Atmos* 5.1.4 or if I should go with 5.1.2 . This is one of key factor driving up the cost so I want to be sure if this is worth it with my room size or is it totally overkill?
- After I have decided on the route to go I will have further questions regarding placement of the speakers, mostly about the surrounds. Due to the couch being wide(2.30m~) its hard to have them according to dolby specifications so having them a tad further back as well as having them further up on a wall-mount tilted down to the listening positions...is this pure blasphemy? I've heard this is not optimal when using atmos due to possible separation issues.
Speaker questions & feedback
I have been looking at the Triangle Borea series as main speakers as I think they are within the price range and I demoed them at my local shop (Br07 floor speakers in this case) and they sounded clear & bright which I liked. Also bying them in a 5.0(or 5.0.2) package they are a lot cheaper.So here is my suggested list to buy:
Speaker | Name | Specifications | Link |
Tower | Triangle Borea BR07 | 2.5way. 91db sensitivity. 44 Hz–22 KHz (+/- 3dB) | Website |
Center | Triangle Borea BRC1 | 2way. 90db sensitivity. 57 Hz–22 KHz (+/- 3dB) | Website |
Surround | Triangle Borea BR02 | 2way. 89db sensitivity. 51 Hz–22 KHz (+/- 3dB) | Website |
Atmos | XTZ Cinema S2 Atmosphere | 2way. 86db sensitivity. 80 Hz–30 KHz (+/- 3dB) | Website |
Atmos | Triangle Borea BRA1 | 2way. 89db sensitivity. 90 Hz–22 KHz (+/- 3dB) | Website |
Subwoofer:
Sub | XTZ 12.17 Edge | 12" ported. 19 - 180 Hz (+/- 3dB) | Website |
My thoughts:
Subwoofer: I'm very confident in my choice of subwoofer. Seems to be one of the better bang for your buck subs in Europe with a lot versatility due to its different EQ:s, PEQ and adjustable ports/seals.Main speakers: there are soooo many brands out there, and not all available for test listening but I'm somewhat confident in my choice of the boreas after reading and researching.
Question 3: The borea towers: should I upgrade the BR07 to to BR08 for 60-150€ extra? It adds one extra woofer and reliefs the mid of having to play low frequencies since its 3way setup instead of 2.5way... but on the other hand since I'm using a subwoofer I dont need more bass from my towers since they are cut anyways with the crossover?
Question 4: Feedback on speakers?
Receiver thoughts/feedback
I have been looking at the following: Depending on question #1:For 5.1.2 :
- Denon AVR-X1700H (750€),
- Denon AVR-X2700H (950€),
- Marantz SR5015 (1140€)
For 5.1.4 :
- + Has a composite analog video input switch so I could dust of my NES & SNES (tho since it does not convert the analog I need to invest in an upscaler, perhaps a retrotink).
- + Audyssey MultEQ XT32 which I’ve heard good things about (tho in practice I know nothing about the differences compared to the lower tier ones)
- - Only has 1x HDMI 2.1 input but workaround is E-ARC via TV which has 4 so im not even sure this is a real issue…
- - It seems to some features that I most likely won’t be needing and I feel “bad” for wasting money on them: like pre-outs
Question 5: Feedback on my AVR thoughts?
Conclusion
While my room is far from optimal and I'll most likely have to compromise on speaker placement following dolby's specification id still like to do what works best for the room and to have it somewhat "future proof"(tho I dont really have thoughts expanding, more of from a feature stand point I want to be able to have it future proofed). Am I on the right track and does my setup make sense for the room type?Any feedback would be greatly appreciated!
