First ever LCD, First ever problems with LCD.
Discussion in 'LCD & LED LCD TVs Forum' started by Hysteria, May 23, 2004.
Tags:
  1. Hysteria
    Hysteria
    Ok so dad bought a cheapish LCD for downstairs, so i was watching a dvd and it changed seen then rite at the bottom of the screen i noticed a bright red dot, so I skipped a seen. Still there, changed back to the TV tuner still there. I've never had an LCD before i but I've herd about dead pixels and i suspect that could be it, please shed some light on the subject.
  2. azzo
    azzo
    Feb 13, 2002
    1,009
    38
    Wokingham
    +9
    What you have is an open red pixel.
    Unfortunately it is unlikely that a retailer will swap it out for another as manufacturers have tolerance levels based on numbers and positions of pixels.
    If the retailer has a refund policy, JL, argos etc then you may be in luck, then again 1 open pixel may not be too bad anyway.
    Azzo.
  3. Hysteria
    Hysteria
    Ok then. I got the TV yesturday, so would this going in a day be a sighn of more to come?.
  4. Chris5
    Chris5
    Mar 21, 2004
    1,290
    63
    Herts., uk
    +179
    This is one of the problems with LCD. The answer to your question is probably not, there are programs you can run on a pc that can sometimes unstick stuck pixels, I don't know where to download them from though, maybe someone else knows.
  5. Hysteria
    Hysteria
    Ok, so it's a stuck pixel?, somebody said it could be a dead pixel in the red layer?. If sombody could find me one of thies programs i would realy apreciate it. I've tired a fiew things already to unstick it but I've had no luck.
