First DVD recorder.
Discussion in 'Blu-ray & DVD Players & Recorders' started by chilpillphil, Dec 23, 2003.
  1. chilpillphil
    chilpillphil
    I want a DVD recorder to copy over my videos and to copy from my sky plus
    How easy is it to back-up (ie copy) my existing dvd movies, films and dvd's such as the office, and on a tight budget - what recorder do you recomend?
    Andrew
  2. kenfowler3966
    kenfowler3966
    Jul 23, 2001
    844
    leeds UK
    +14
    No recorders will copy protected material out of the box. You have to buy expensive leads to overcome the protection, and it is probably better to use a computer for this as once you have a dvd recorder in a computer there is free software available to allow back-up of complete dvd's.
    Remember that many video's, particularly disneya are well protected, as are films from sky box office etc.
  3. ivanwilson
    ivanwilson
    Oct 31, 2003
    111
    Belfast
    I do not condone copying but unfortunately discovered that I could do it with my Philips DVDR70 and Compacks 5000 (Safeway). No special leads are needed and it seems to copy any DVD, any region and NTSC discs. I have never done it since - honest.
    Anonymous!
  4. clayts450
    clayts450
    Jun 25, 2001
    558
    2
    Nottingham
    +51
    Ivan - are you saying CGMS/A is disabled as well on the DVD5000, as well as "the other" ? If so that's incredible :)
  5. chilpillphil
    chilpillphil
    i only would copy as a back-up, and to keep the originals in good condition (as i said)
    I would also like to copy my videos, so i can chuck out the vcr.
    Might risk it, or just only buy a pc dvd recorder.
  6. ivanwilson
    ivanwilson
    Oct 31, 2003
    111
    Belfast
    Clayts450
    Absolutely - although I don't really know what CGMS/A is! When I first got the DVDR I was trying (for experimentation only!) to backup a DVD using a different player. I knew about Macrovision and had the old Bugblaster in use but I got the 'Copy Protected' message. I was going to give up but thought I'd give the Compacks a rattle and, hey presto it worked like a charm.
    Thanks for all the good info on your site by the way. Merry Christmas and a happy new year.
  7. ivanwilson
    ivanwilson
    Oct 31, 2003
    111
    Belfast
    chilpillphil
    Yes you can go down the PC writer route but I don't know if it's worth all the hassle. You'll need analogue input for copying tapes and the feed from your sky+ box. I'd recommend a set top box.
  8. chilpillphil
    chilpillphil
    im confused, so what do i need to buy, i want to get the panasonic dvd recorder for £250
    Will this be ok
  9. ivanwilson
    ivanwilson
    Oct 31, 2003
    111
    Belfast
    That would do the job OK - doesn't write to - RW though, only RAM. So if you record to RAM you won't be able to play your recording on the vast majority of other players.
    For archiving etc I'd say go to +RW (but '-' format is good and has its advantages OK). No discussion phelings et al - it's the time of goodwill to all men :)
  10. chilpillphil
    chilpillphil
    Damn, thats pointless then, if i carnt play it on my other sony dvd player
  11. ivanwilson
    ivanwilson
    Oct 31, 2003
    111
    Belfast
    chilpillphil
    Well the Panasonic will record to - R and you could play that on your Sony, but -R is a write once format only. But if you intended to keep everything you recorded it would do.
  12. chilpillphil
    chilpillphil
    i suppose, ATM i can just use sky plus and copy the thinks i really want to keep
    thanks
    ill see how much they are at my local store,
  13. phelings
    phelings
    Jul 24, 2003
    1,025
    36
    Kenfowler exaggerates slightly-the lead from
    www.sonel.com
    that allows copying is £19.99.Hardly expensive,and far superior to any black box device
  14. nwgarratt
    nwgarratt
    May 5, 2002
    26,252
    +2,820
    It is to stop copies made from commercial DVD's to a DVD Recorder or other digital device. It also affects the audio if you try to record digitally to minidisc.
