First Build
Bigskuse
Right well.... I'm a newbie when it comes to hardware.
This will be my first build (i would have one built for me but I want to buy the parts monthly because of a lack of funds)
This is the list of components that I have selected, I was just hoping that someone could confirm that all the hardware will run/fit/work together.
Computer Mock Up
Case
Saturn Black ATX Gaming Case With Blue LED fans
£24.95
Item Code : CA-XSATURNBL
Item : Saturn Black ATX Gaming Case With Blue LED fans
Brand/Model : Generic CSCITSATURNB
Form Factor : ATX
PSU : No
Side Window : Yes
5.25" Bays : 4
3.5" Bays (Exposed) : 1
3.5" Bays (Hidden) : 5
Expansion Slots : 7
Front USB Ports : 2
Front Audio Ports : Yes
Front Firewire Ports : No
Internal Fan Space : 1x120mm, 1x80mm
Screwless : No
Dimensions (wxhxd)-(mm) : 186 x 420 x 451
Warranty : 12 Months
Weight (kg) : 6.00
Price : £24.95
Eclipse Computers - Product Details
Mother Board
Asrock 970DE3/U3S3 AM3+, DDR3, 7.1 Snd, GBLan, ATX
£39.50
Item Code : MBA-970DE3U3
Item : Asrock 970DE3/U3S3 AM3+, DDR3, 7.1 Snd, GBLan, ATX
Brand/Model : Asrock 970DE3/U3S3
Chipset : AMD 770
FSB : Hyper-Transport 3.0 (HT 3.0) Technology
CPU Socket : AM3+
SLi : No
CrossFire : No
Memory Type : Dual Channel DDR3
Maximum Memory : 32Gb
Max. Memory Speed : DDR3 1866(OC)/1600(OC)/1333/1066/800
IDE Channels : 1
SATA Channels : 6 x SATA2 3.0 Gb/s, 2 x SATA3 6.0 Gb/s
SATA Speed : 150/300/600
External SATA : 0
Graphics Slot : 1 x PCI Express 2.0 x16 slot
No. of PCI Slots : 3xPCI-Ex1, 2xPCI
USB 2.0 : 4
USB 3.0 : 2
LAN : PCIE Gigabit LAN
VGA : No
Sound : 5.1 CH HD Audio (Realtek ALC662 Audio Codec)
PS/2 Ports : Mouse / Keyboard
Parralel Port : 0
Serial Port(s) : 1
Form Factor : ATX
Bundled Software : Drivers
Additional Features :
Overclocking Features :
Weight (kg) : 2.00
Price : £39.50
CPU
AMD Bulldozer FX-4100 3.6GHz AM3+ Black Ed Processor –Retail
£64.75
Item Code : CPA-FX4100
Item : AMD Bulldozer FX-4100 3.6GHz AM3+ Black Ed Processor -Retail
Brand/Model : AMD FD4100WMGUSBX
Capacity : 3.6GHz
Front Side Bus : HT 3200MHz
Cache : 8MB Total Cache
Socket Compatability : AM3+
Core Type : Orochi Core
Type : Retail
Other : Quad Core
Weight (kg) : 1.50
Price : £64.75
CPU Cooler
Socket AM3 CPU Cooler For AMD CPU's
Item Code : HF-SOCKAM3
Item : Socket AM3 CPU Cooler For AMD CPU's
Brand/Model : Generic Z7UH40Q001
Socket Type : 754,939,940,AM2,AM2+,AM3 & F
Max CPU : AMD Phenom II X2, X3, X4, X6 (ALL)
Bearing Type : Dual Ball Bearings
Speed (RPM) :
Airflow :
Noise :
Heatsink Material : Copper heatpipes, base w/ bonded aluminum fins
Connector : 4-Pin PWM
Dimensions (wxhxd)-(mm) : 92 x 84 x 94
Weight (kg) : 0.25
Price : £4.95
£35.95
Memory
16Gb (2x8Gb) Dual Channel DDR3 1333MHz Memory Kit
Item Code : ME-D3-16GBD13
Item : 16Gb (2x8Gb) Dual Channel DDR3 1333MHz Memory Kit
Brand/Model : Generic 16GB-DDR3-1333D
Bus Speed : 1333MHz
CAS Latency : Various
Number of Pins : 240-Pin
Other :
Weight (kg) : 0.25
Price : £35.95
Hard drive
1TB W.Digital Caviar Green 5400RPM 64Mb SATA3 Hard Drive
£44.95
Item Code : HDW-1000EARX
Item : 1TB W.Digital Caviar Green 5400RPM 64Mb SATA3 Hard Drive
Brand/Model : Western Digital WD10EARX
Capacity : 1Tb
Spin Speed : 5400rpm
Buffer : 64Mb
Access Time : 4.2ms
Interface : SATA3
Bearing Type : Fluid Ball
Weight (kg) : 1.25
Price : £44.95
Graphics card
1024Mb nVidia GeForce GTX 560Ti PCI-Express VGA Card
£119.95
Item Code : GC-XNGTX56T1
Item : 1024Mb nVidia GeForce GTX 560Ti PCI-Express VGA Card
Brand/Model : Generic NVIDIA GTX 560TI
Graphics Engine : NVIDIA GeForce GTX 560 Ti
Video Memory : GDDR5 1GB
Core Clock : 822MHz
Memory Clock : 4000 MHz ( 1000 MHz GDDR5 )
Vertical Refresh Rate : 60-240Hz
Max. Display Mode : 2560x1600
Bus Standard : PCI Express 2.0
RGB Out :
DVI Out :
TV-Out : Mini HDMI
TV-In : No
Dual View : Yes
DirectX Compliance : DirectX 11
Software : Drivers
Weight (kg) : 3.00
Price : £119.95
Power supply
Xigmatek 500W NRP-PC502 Power Class PSU
Item Code : PSX-500NRPPC
Item : Xigmatek 500W NRP-PC502 Power Class PSU
Brand/Model : Xigmatek NRP-PC502
Input Voltage : 115Vac/8A max. 230Vac/5A max.
Total Output Wattage : 500W
Power Switch : Yes
5.25" Device Power Connectors : 6 Molex
3.5" Device Power Connectors : 4 SATA
Monitor (IEC) Follow-through Power Connector : No
Weight (kg) : 4.00
Price : £39.50
Optical Drive
LiteOn IHAS122-18 22xDVD Writer, SATA, OEM
£12.50
Item Code : DRL-IHAS12218
Item : LiteOn IHAS122-18 22xDVD Writer, SATA, OEM
Brand/Model : Liteon IHAS122-18
Interface : SATA
CD-ROM Speed (Max) : 48x
CD-R Speed/s : 48x
CD-RW Speed/s : 32x
DVD ROM Speed (Max) : 16x
DVD R Write Speed/s : 22x
DVD RW Write Speed/s : 8x/6x
DVD R Format (+/-) : +/-/DL/RAM
Buffer (Mb). :
Dual Layer : Yes
Data Capacity : 8Gb
Average Random Access Time :
Writing system :
Bezel Colour : Blac
Supported CD Size : 8 and 12cm
Inc. Software/Media : None
Supported OS :
Supported Modes : SMART-BURN and SMART-X technologies
Package Type : OEM
Manufacturers Warranty : 12 Months
Weight (kg) : 1.25
Price : £12.50
brookheather
A few points - why are you buying an extra cpu cooler (it looks like the standard one you already get with retail cpus) - why 16GB of ram - 8GB should be more than enough - the 1TB hard drive is only 5400rpm and will be a bit slow if you are using this as your main drive - have a look for a 7200rpm one.
Bigskuse
This is me being too hastey to select items :) Thank you for pointing this out to me. Other than your suggested changes, are there any other changes you feel need to be made?
brookheather
Well as you are getting a separate graphics card I wouldn't buy an AMD setup - I would buy a budget Intel H61 or B75 motherboard plus a Core i3 cpu.
EndlessWaves
What are you using it for? Given the high ram and FX processor it would seem like some sort of modelling or maybe video editing setup?
You want DDR3-1600, it won't make a lot of difference for many uses but it's the same price so it doesn't make any sense to buy the slower DDR3-1333.
The GTX 560ti is a horrible card generally, overpriced, inefficient and slow. If you need to go nVidia then the GTX 650ti is a much better choice with 90% of the performance but half the power consumption and a significantly lower price.
You don't need a large 500W power supply for that setup, especially if you switch to a more efficient card. 300-400W of reasonable quality is fine.
