Hi guys,
This is the first build I've ever done so looking for all the help and guidance on the subject. I'm hoping to build a modest gaming system, nothing too fancy though I just want to have most games available to me. So here's the set up I plan so far:
Motherboard: MSI 870A-G54 Socket AM3 8 Channel Audio ATX Motherboard | Ebuyer.com
CPU : AMD Phenom II X2 555 Black Edition 3.2GHz Socket AM3.. | Ebuyer.com or AMD Phenom II X4 840 Socket AM3 3.2GHz 2MB Cache.. | Ebuyer.com
GPU: Scan.co.uk: XFX HD 5770 AMD / ATI Graphics Card with IP-5X fan, Eyefinity, Single Slot - 1GB - HD-577X-ZMF3
RAM: Scan.co.uk: Corsair Memory XMS3 4GB DDR3 1600 MHz CAS 9 XMP Dual Channel Desktop - CMX4GX3M2A1600C9
HDD: Scan.co.uk: Hitachi Deskstar 1TB 7K2000 Hard Drive - HDD - 0F10383
and for the PSU would it be sufficient to buy a case/psu bundle similar to Casecom 7720 Black Mid Tower Case with 450W 24pin SATA.. | Ebuyer.com with a 450-500W psu?
Is this setup ok? also are there any overkill or weak components compared to the others? I'm not confident in this area so any and all help will be greatly appreciated, especially if you have any part replacement recommendations
