ThePowster
Established Member
Hi folks
Newbie here starting my very own first DIY project at the tender age of 36
OK my plan is to turn my living room into a home cinema, so to start with my first project is to build a radiator cover which spans the whole length of my living room as my radiator isnt central and am a tad OCD
So, I have built my rad cover and I am very proud of that and today I ordered Black Faux Leather Vinyl Upholstery Fabric to cover it in.
So my question is ...
How can I cover the MDF in this fabric in the cheapest most cost effective way possible ?
I have looked at sealing the MDF but the sealant is £25 and then I looked at 3M spray glue but I dont want to be spraying lots of that in my living room as my rad cover is approx 3.5m long.
So I wanted to ask would this product be ok and do the job of both sealing the mdf and at the same time adheering the vinyl to the mdf ?
UniBond Super PVA Adhesive Sealer & Primer 500ml, 5010383000165
And this is where I am with it:
I am worried if I try this and get it wrong I'll have to re-buy the vinyl and waste a lot of money so I came here for some advice.
Many thanks in advance.
Matt
Matt
