Firmware ( which country? )
Discussion in 'Headphones, Earphones & Portable Music' started by Dreamin_Shadow, May 11, 2005.
  1. Dreamin_Shadow
    Dreamin_Shadow
    Hi, I recently purchased and 40 gig Iriver MP3 player ( H120 )
    I want to update the firmware for it, but I am unsure of what one to get. I have heard all sorts of conflicting advice! Some day that the newest EU firmware removes the volume capping that was a French directive. Is this true? If it is true, then my problem is solved! I will just install that firmware. If it's not true, then should I install the US firmware? If I do this, I hear it comes with DRM. I have seen it suggested to install the Korean firmware, but would that not make all of my menus be displayed in Korean?
    Thanks in advance. :)
