Firmware update
Discussion in 'Projectors, Screens & Video Processors' started by RTFM, Aug 18, 2004.
  1. RTFM
    RTFM
    Mar 6, 2003
    1,014
    38
    Horsham, West Sussex
    +17
    If anyone wants to upgrade their Sim2 Firmware to the latest version email me at projectors@eurobell.co.uk
    Domino 20: 2.35.05
    All HDMI models excluding the 300/500 Link: 2.36.09
    300 Link: 2.37.04
    500 Link: 2.38.02
    200/250/200DMF also available
    Jeff :rtfm:
  2. Peter Dunn
    Peter Dunn
    Hi Jeff,
    I have a Sim2 Domino 20, purchased from new in February 2004. Would my system gain by upgrading with the latest firmware?
    Many thanks,
    Pete
  3. RTFM
    RTFM
    Mar 6, 2003
    1,014
    38
    +17
    Pete,
    There are some worthwhile improvements.
    Send me an email and I will send you the new s/w which also includes a pdf file of changes made.
    Jeff
  4. Peter Dunn
    Peter Dunn
    Thanks, Jeff. Email sent.
    Regards,
    Pete
  5. TopMeTom
    TopMeTom
    Sep 8, 2002
    8,331
    +261
    Hi Jeff,
    what about my 200dm,would it be worthwhile?
    Cheers,
    Phil
  6. RTFM
    RTFM
    Mar 6, 2003
    1,014
    38
    +17
    Hi Phil,
    I only have s/w for 200/250/200DMF
    I will check with Sim2 to see if there was an upgrade for the 200DM.
    BTW, what's your s/w version ?
    Jeff :rtfm:
  7. TopMeTom
    TopMeTom
    Sep 8, 2002
    8,331
    +261
    :blush: Would not know mate at the moment,assume it had the latest on it when I picked it up from your good self.
    Phil
  8. cameronl
    cameronl
    Aug 13, 2002
    1,217
    38
    +11
    hi there :)
    Do you know what the latest software version of the Sim2 DMF is? I think my software is 2.15.
    thanks
    CaM
  9. RTFM
    RTFM
    Mar 6, 2003
    1,014
    38
    +17
    Phil,
    Next time you fire up the PJ, press the info button on the r/c and it will tell you the s/w version.
    Jeff :rtfm:
  10. RTFM
    RTFM
    Mar 6, 2003
    1,014
    38
    +17
    CaM,
    the latest s/w for the DMF is 2.18.01.
    If you want it send me an email as in the first post.
    Jeff :rtfm:
  11. figlio
    figlio
    Dec 17, 2002
    180
    Malta
    I have a friend that have a DOMINO 20 without HDMI.He has the latest software in it. Does anyone noticed that on REGION2 dvds the tint is still working.
  12. TopMeTom
    TopMeTom
    Sep 8, 2002
    8,331
    +261
    My software is 1.2?
    Phil
  13. RTFM
    RTFM
    Mar 6, 2003
    1,014
    38
    +17
    Phil,
    When Alan gets back from Cedia I wll check on the latest version for the 200DM
    Jeff :rtfm:
  14. TopMeTom
    TopMeTom
    Sep 8, 2002
    8,331
    +261
    Cheers for that Jeff,
    Phil
  15. godzilla
    godzilla
    Oct 10, 2002
    661
    Lightwater
    +14
    Hi Jeff, this is a bit O/T but my HT300 (original) has just packed up after about 2300 hours. Still gets power and there is a quieter-than-normal hum on start up but no light. Does that sound like the lamp has gone?
    The other problems I have always had with this unit is that:
    1) prog scan doesn't work properly with my Denon DVD A-1 as the picture comes out with a slight green tinge and a kink about a third of the way down.
    2) on PC input I get a wavy screen on anything other than 800 x 600 resolution
    Are they problems you have had any experience of?
    Anyway it is on its way back to Sim2 and I've asked them to look into these issues as well as updating the firmware.
    Any idea what the latest firmware is for the original HT300?
    Many thanks for your attention.
  16. RTFM
    RTFM
    Mar 6, 2003
    1,014
    38
    +17
    Sounds like it could be the lamp.
    I have not had any problems with prog scan (PAL or NTSC) into the 300.
    PC should work fine set to 1280 x 720. Again I have had no problems running at the native res.
    Jeff :rtfm:
