Managed to setup the remote pc play very quickly which was good but while playing Fifa the colours seemed pretty dull despite my monitor being good and usually displaying very vivid bright colours.
Is this down to the 720p? Or anything I can do to change it?
You can set it up to work direct connection to the ps4 or internet. It doesn't work direct through home network unfortunately which is why your broadband upload speeds are important.Works the same as Vita and PSTV for me.
Who said it's over the net? it's over home network...
Was like this for Vita. So you can play away from homeWhy is it doing it over the net? Had a go today and while it was ok i'm baffled why they are doing it over the internet and not your own network. Should easily be able to do 1080p on my own Network if they did it like that.
I thought the same, but I think I was just used to playing FIFA on my TV which is more vivid than my monitor. My monitor is set to be duller and with more accurate colours due to me using it for editing photos.Managed to setup the remote pc play very quickly which was good but while playing Fifa the colours seemed pretty dull despite my monitor being good and usually displaying very vivid bright colours.
It must do as my upload is 0.7mbit and gaming was fine as I said - just like vita and PSTV. No way that speed can do 720p and 60fps otherwise.You can set it up to work direct connection to the ps4 or internet. It doesn't work direct through home network unfortunately which is why your broadband upload speeds are important.
I'm sure it's over the net. Requires certain speeds of your Internet.It must do as my upload is 0.7mbit and gaming was fine as I said - just like vita and PSTV. No way that speed can do 720p and 60fps otherwise.
ie:
- If you are connecting the systems directly using Wi-Fi, select
(Settings) > [Remote Play Connection Settings] from the PS4™ system's function screen, and then select the [Connect Directly with PS Vita/PS TV] checkbox to set a checkmark.- If you are connecting the systems using a wireless access point, the systems must be connected to the same network.
That's if you want to play literally remotely - on Vita etc via WiFi elsewhere away from home.I'm sure it's over the net. Requires certain speeds of your Internet.
Yeah it is slow considering they ask for "Generally, we recommend a high-speed connection with upload and download speeds of at least 5 Mbps."That's if you want to play literally remotely - on Vita etc via WiFi elsewhere away from home.
There is absolutely 100% no way 0.7mbit upload would deliver what it does. It works precisely the same as my Vita and PSTV, I.e., 720p 60 silky smooth with slightly dulled colours.
I get the "searching the internet" message in all three devices. I believe it's just a standard wording.
I don't understand how it can only be limited to 720p then if you can use you're own network. Just felt a little bit poor on my network which is absolutely fine, even wirelessly.
Didnt the PSTV do 1080i though?Something to do with memory allocation, 720/60 is the best they can do without impact game performance. Also same for streaming.
It looks about the same as PC remote play regardless!Didnt the PSTV do 1080i though?
