FevreDream
Can't wait to get home at 5:15pm and finally be able to install the 2 TB WD SN850 SSD I've had for the last 3 or 4 weeks. I was really annoyed that I never got a beta invite, despite dozens and dozens of registrations, but I guess that doesn't matter now.
Is the panel easy to take off the PS5 as I've never had any reason to remove mine until now? I understand that you need to first remove the base then lift the panel up by the top-right corner and at the same time slide it down slowly and gently to avoid scratching the interior plastic. Is that right?
Already made a note to remove the disc then use the safe remove option for the external SSD and then finally shutdown the PS5 (as opposed to putting in Rest mode as I usually do). If I didn't do that then I know I would have forgotten one or more of them in the excitement to install the new SSD!
I’ve always found taking the covers off easy enough. Just lift the top right corner and slide it down, as you said. I take them off regularly to clean inside. It’s surprising how much dust collects underneath.
