Firmware for AV192R, 250MR, 250x3R
Discussion in 'AV Receivers & Amplifiers' started by alxm, Jul 15, 2015.
Tags:
  1. alxm
    alxm
    Feb 21, 2008
    48
    Sydney
    +17
    I have recently purchased some used Tag McLaren gear and was wondering if anyone can point me to where I can download the latest firmware / software update files and the firmware loader program. I remember seeing them on Tag section of IAG website but as we know that webpage is still not working.
    I have the following versions of software which I believe is a few versions below the latest:
    AV192R - FW 4.08
    250MR - FW 3.79
    250x3R - FW 3.79
    I suppose I should ask the secondary and more important question I have, which is: Is there any point in upgrading to the latest firmware? Particularly in the case of 192R I have, it is a bare bones Audio-ONLY processor with Balanced XLR outputs being the sole option fitted. Nothing video related on it, which is the reason I bought it, to upgrade my AV32RDP. Is it fair to assume that most of the firmware upgrades were for video related issues rather than audio? Or were there enough bug fixes to warrant the use of latest software?
    I am aware that I need to purchase DPLIIx license to upgrade to 4.31, which I am still able to get from IAG. I don't use DPLII anyway, so upgrade to 4.10 may be sufficient.
    Any opinions and download links or files held by the wise Tag McLaren community, in particular the long standing owners of these wonderful products would be greatly appreciated.
    Thanks in advance.
  2. AMCross
    AMCross
    Dec 3, 2003
    6,066
    Livingston,Scotland
    +217
    send me your email address and i will send the last firmware they made
  3. AMCross
    AMCross
    Dec 3, 2003
    6,066
    Livingston,Scotland
    +217
    open this with paint etc and make larger you can see some of the improvements on one update
  4. AMCross
    AMCross
    Dec 3, 2003
    6,066
    Livingston,Scotland
    +217
    amp software and upgrade wizard sent
    last av192r firmware sent but you know about the pl2x software
    also there is a dts fix that was released BUT i would proceed with caution on using it as i has broken some dual proccessor boards and IAG will not/Cannot help or fix
  5. tiff_lee
    tiff_lee
    Nov 23, 2009
    401
    Western Australia
    +33
    Even the amps have firmware? is that all to do with the Tagbus control side of things?
  6. karlknurr
    karlknurr
    Aug 19, 2012
    240
    +23
    Yes that is correct. But for the amp it is not so important to use the latest firmware. If the communication works fine you can stay with your current software.
  7. tiff_lee
    tiff_lee
    Nov 23, 2009
    401
    Western Australia
    +33
    I don't even use the Tagbus so would definitely make no difference to me I was just initially surprised it had firmware thinking it was all 'hardware' but then I completely forgot about the tagbus.
  8. karlknurr
    karlknurr
    Aug 19, 2012
    240
    +23
    As I rember correctly the changed in the past also the starting senquence. The first generation of 100x5r amps uses 2 relays per channel. With the latest firmware the clicking was a little bit different then before.
  9. karlknurr
    karlknurr
    Aug 19, 2012
    240
    +23
    Here you can find the latest software for the AV192R and your amps.
  10. alxm
    alxm
    Feb 21, 2008
    48
    Sydney
    +17
    Thank you very AMCross and karlknurr for the firmware files.
    Just a word of warning to anyone doing this upgrade using a laptop with a USB to RS232 adapter to connect the Tagtronic cable. DON'T DO IT. Use a PC with an actual RS232 serial port.
    Does anyone have AV192R FW 4.31 with the DTS Fix by Stevesky?
    Cheers.
  11. AMCross
    AMCross
    Dec 3, 2003
    6,066
    Livingston,Scotland
    +217
    Please find attached the proposed fix for the DTS problem. I have also
    > attached the utility for reflashing a DSP without having to reprogram
    > the rest of the unit.
    > Unzip the attached zip file. The password is "TAG".
    > Copy the files attached to a directory of your choise. eg. C:\dts fix\
    > Rename sharcflasher.abc to sharcflasher.exe
    > Next rename tagtronic.bcd to tagtronic.dll
    > Connect up the BLACK sleeved plug on the tagtronic lead to the av
    > processor TAGTRONIC out socket. Do this wHILE the processor is
    > switched on. Leave the RED sleeved plug diconnected.
    > Load up the sharcflasher.exe utility. Click on the Browse button and
    > pick the "av32d43101-0-2.dsp" file to download. Click OK to finalise
    > selection.
    > Ensure that the comm port setting is correct (com1?).
    > Ensure that the DSP to download to is set to 1.
    > Hit the "Download" button.
    > Hopefully the processor should show "DOWNLOAD" on the front display
    > with something like "Upgrading DSP"
    > underneath it, with an hour glass twirling around.
    > Wait until 100% is reached on the download. The processor will
    > continue to say on the front that it is downloading... ignore this!
    > Switch off processor. Wait about 5 seconds. Switch processor back on.
  12. AMCross
    AMCross
    Dec 3, 2003
    6,066
    Livingston,Scotland
    +217
    PROCEED WITH CAUTION
    I ACCEPT NO RESPONSIBILITY IF IT DAMAGES YOUR DP CARD
  13. zjager
    zjager
    Jul 17, 2015
    Germany
    Hi All,
    I have bought a Tag Mclaren T32R Tuner with no DAB Option. I´m now looking for the actual Firmware (I think it might be the V4.7). My tuner is still running the V1.04).
    Can you help? Or do you know anyone hwo can help?
    My eMail is [email protected]
    Many thanks in advance!
    ZJAGER
  14. karlknurr
    karlknurr
    Aug 19, 2012
    240
    +23
    Hi, as far as I know the last firmware was V37.
    You can find this firmware in the attachment.
