Firewire
Discussion in 'Camcorders, Action Cams & Video Editing Forum' started by Pids, May 23, 2003.
  1. Pids
    Pids
    Hi, I have been given a Thomson VMD5 camera, iwant to transfer footage to computer hardrive.
    What kinds firewire card would be best in a DELL Dimension 4300?
    Any ideas
    Cheers guys and girls
  2. Cheng
    Cheng
    Dec 19, 2002
    374
    +6
    I'm not too hot on firewire cards, but I don't believe there *should* be much of a difference between cards...(from a PC perspective) i.e. They're all at the same spec, right?
  3. MarkE19
    MarkE19
    Aug 10, 2002
    17,132
    Rainham Essex
    +2,393
    The only real difference between firewire cards is if there are hardware CODECs onboard.
    Standard firewire cards are all the same and do not have the CODECs onboard. These cost from around £20.
    Hardware CODEC cards give the likes of real time output of effects and cost several hundred pounds up.
    To start with you will be better off saving the extra amount and just getting a basic card from the likes of DABS or EBUYER or any other cheap retailers/computer fairs.
    Mark.
  4. scott69
    scott69
    I also have a dell 4300 and installed a firewire card about 6 months ago. Just buy the cheapest one available!!!
    I got mine at dabs.com for £13. although they seem to have hiked the prices up since then. I am presuming you have win xp.
    If not, I'm not sure how easily firewire cards can be installed.
  5. Pids
    Pids
    thanks all, what software do you use with the Dell
  6. MarkE19
    MarkE19
    Aug 10, 2002
    17,132
    Rainham Essex
    +2,393
    A very popular programme for editing is Pinnacle Studio 8.
    This easy to learn, but has loads of advanced features.
    Mark.
