Firewire Optical Drives
Jezrh
Hi all,
I have a few questions here...
Firstly, I have a 13" MacBook (white) with a Firewire 400 port. I have plugged into it a WD 1.5TB external HDD (Firewire 800 drive with 400 adapter). The WD drive has a spare 800 port on the back... Am I right in thinking this is for "daisy-chaining"? If so, how does it work?
Secondly, I saw a thread on a different forum about Firewire Optical Drives (although it was dated back to 2007, would like some more recent feedback if possible ;) )...
I've found a Firewire OD on ebuyer which says it'll read BDs and HD-DVDs, and write DVDs (and therefore, presumably, CDs?)
Freecom 33979 8x BD-ROM with DVD±RW DL &amp.. | Ebuyer.com
Will this work when plugged into a MacBook? And then, if it will, will I need additional software to play BDs / HD-DVDs with it?
I'd quite like to be able to rip BDs / HD-DVDs if possible and then convert them into streaming friendly HD films, can this be done? I use Handbrake to rip DVDs, will that work for them too?
Hope this all makes sense... Sorry for the long post :facepalm:
Thanks in advance,
Jez
Tenex
Yes that's right plug the next firewire device into the other port, job done.
Can't help with the OD - Macs don't support Bluray (though Toast will burn them I think).
nigelbb
OS X does support Blu-ray just not Blu-ray video disks. You can burn data to Blu-ray disks without any extra software.
