daverwhite
I have a Sony DCR51E camcorder and a HP Dv7 1000 laptop.
With Vista i used to connect the firewire cable and the camcoder would be recognised automatically, (with two "ding" sounds) and i would be able to import video with Windows Movie Maker.
After installing Windows 7 i cannot do this. I have downloaded and installed Windows Movie Maker as part of Windows Live, (as it is not included in Windows 7 as standard) and i have updated my drivers but the firewire cable/camcorder are no longer recognised when i connect them up.
I have tried a new, (4 pin to 4 pin, same as the original), firewire cable from Maplin but this makes no difference.
Please can you advise of any way to fix this problem?
