Firewire Card
Discussion in 'Camcorders, Action Cams & Video Making Forum' started by andystud, Apr 14, 2002.
  1. andystud
    andystud
    I'm looking to buy a firewirwe ieee1394 card for my PC, but the cheapest i can find is about 50 pounds, while people have been posting saying they're about 25-30 pounds.
    I don't need the software as i already have some so can someone advise me on where to look for the card only.
  2. Rathion
    Rathion
    Oct 29, 2001
    Hi I just bought one from Komplett for £35.57 Total.
    Thats 27 + vat + £3 delivery.
    Theres probably cheaper but I thought it was reasonable.
    Comes with cable and some MGI videowave software.
    HTH
  3. Dubbing Mixer
    Dubbing Mixer
    Jan 27, 2002
    643
    By, and sometimes in, the sea
    Check out Scan.co.uk
    They have several including full retail boxed with a cable(a not insignificant freebie if you need one) For between 20 and 40 quid. Plus look out for their 'Today Only' specials which make it cheaper still.
  4. YJ
    YJ
    Jul 13, 2000
    54
    9
    Middlesex
    Try dabs value. It is OCHI compliant so it should use standard windows drivers. This one has a different chipset manufacture to the one I bought this one being Lucent and my one being based on the ALI chipset.
    Anyway the price is still low:
    http://www.dabs.com/value/value.asp?s=489
    YJ
  5. andystud
    andystud
    i had already noticed the Dabs priced and placed an order.
    £18 in total. Ordered it 6:30 on tuesday and it arrived on wednesday.
  6. dmckillop
    dmckillop
    If you're due to upgrade your sound card, you could get a Soundblaster Audigy with built in Firewire port.
    I've got one and it works fine with Premiere and Studio DV.
  7. Guest
    I have a sound blaster audigy card. I'm seriously thinking of going digital and Im a bit confused re firewire cables.
    I've seen cable connectors advertised with 4-6 pin Etc. can you tell me the pin size of firewire cable I need to connect into my sound blaster audigy firewire port.
    Thanks in advance
    Gerabus
  8. whiskers
    whiskers
    I have just found out that there are several firewire cards. If you want it for using on a DV camcorder then make sure it is an IEEE1394. I purchased a Belkin F5U104 and it is basically only for games.
  9. YJ
    YJ
    Jul 13, 2000
    54
    9
    Middlesex
    The Audigy has 6 pin cable connector and most DV cams & DVHS players have 4 pin connectors. The two pins that have been remove carry power, across the cable.
    Most if not all have firewire cards have 2 or 3 external ports they are 6 pin. Generally you get a 6 pin to 4 pin cable packaged in the box when you purchase a firewire card.
    If for any reason you wish to buy an additional cable just visit www.jetmedia.co.uk/ I find their prices to be very competitive, just look under the USB section for the prices.
    Richard, I’m sorry to hear that you learning about it through the expensive way.
    Hope this helps :)
    YJ
  10. dmckillop
    dmckillop
    Gerabus, you need to turn your private messages on, I couldn't reply to you :)
    All I'm using is a standard 4 - 6 pin cable. I didn't fancy being ripped off at Dixons, so I bought one off Ebay for a fiver.
