Firewire cable
Discussion in 'Desktop & Laptop Computers Forum' started by neilo, Sep 17, 2004.
  1. neilo
    neilo
    Apr 18, 2002
    1,569
    38
    +21
    Does any one know where you could get a firewire cable custom made ..Iomega no longer stock the cable I need and have offered me a new Drive but no way of gettying my files off the old drive ..its not a normal firewire cable
  2. HMHB
    HMHB
    Nov 11, 2001
    26,722
    Nottinghamshire
    +5,489
    Which Iomeage device is it you have ? What does the cable look like that you want to buy ?
  3. neilo
    neilo
    Apr 18, 2002
    1,569
    38
    +21
    its a iomega 120gb external hard drive mormal firewire connecter to the pc but a big connector the other end looks like a small ..how to describe lol the old printer connectors
  4. neilo
    neilo
    Apr 18, 2002
    1,569
    38
    +21
    anyone ?
  5. Crocodile
    Crocodile
    Nov 4, 2002
    18,332
    +6,862
    Something like this? Maybe worth a call to CPC to see if they can provide just the cable if it's the right one.
    If you don't get anywhere with CPC a Google search for "external ide firewire" will produce a whole host of external enclosures. I guess the other options are to buy an enclosure complete & transfer your HDD to it or, if you simply want to recover the files, temporarily install the HDD directly into your PC.
  6. neilo
    neilo
    Apr 18, 2002
    1,569
    38
    +21
    how do i install the hdd into my pc ?
  7. Crocodile
    Crocodile
    Nov 4, 2002
    18,332
    +6,862
    It should be relatively straight forward to remove the drive from the Iomega case & you can then just treat it as a standalone 120Gb IDE that can be installed as a secondary (slave) drive. Without wishing to cause offence, your other thread would suggest that you don't have sufficient knowledge to undertake this. I would strongly recommend that you exhaust the search for a cable first or entrust this job to a professional as it could all too easily end in tears (& no data!).
  8. neilo
    neilo
    Apr 18, 2002
    1,569
    38
    +21
    no offense at all lol
  9. Epithet
    Epithet
    If the cable is going to cost you more than about £20 - £25 it would be worth you googling on installing a new HDD. Alternatively, buy a new external enclosure and move the drive over. A good resource for external enosures, with advice, is www.span.com.
    Good luck
    TonyM
  10. neilo
    neilo
    Apr 18, 2002
    1,569
    38
    +21
    Iomega are offering me a brand new drive as a replacement I just need to get the 60 gig of MP3 off it first lol
