Firefox problems
Discussion in 'General Chat' started by rhoamish, Aug 6, 2006.
  1. rhoamish
    rhoamish
    I really like Firefox. However, since the last update, I can't access the internet with it!
    I use NTL broadband, with Windows XP. I can access the internet with IE, I've uninstalled and reinstalled Firefox, I've even tried giving it new proxy servers to look at, but still it refuses to connect to the internet.
    Anyone got any clues? I've tried googling for the problem, but I've not found anything helpful yet.
  2. eviljohn2
    eviljohn2
    Jul 8, 2002
    7,545
    Near London.
    +208
    I've not had any problems with it, how do you connect to the internet and do other browsers like IE work OK? :)
  3. Steven
    Steven
    Senior Moderator
    Feb 1, 2005
    37,620
    +6,604
    Did you accidentally switch 'offline' on? I did that once :rotfl: Yes really :blush: Doubt you're that slow though :D
    Edit: firewall settings?
  4. shay0
    shay0
    Jan 9, 2005
    5,004
    God's Own County
    +489
    Check your firewall settings. Each time Firefox updates on my machine, the firewall treats it as a new program and asks how I want it handling. If yours is the same set up and you've accidently hit deny, then that would do it :)
  5. rhoamish
    rhoamish
    Thanks for the advice so far, but it's still broken! I connect on a wireless doodad, made by linksys, on a laptop. It used to work, and now it doesn't.
    The strange thing is the PC upstairs still works with Firefox wirelessly (which was also updated automatically) and the laptop works with IE, but not Firefox.
  6. eviljohn2
    eviljohn2
    Jul 8, 2002
    7,545
    Near London.
    +208
    Try this menu combination:
    Tools > Options > General (tab) > Connection Settings (button)
    and set it to Direct Connection to the Internet. That's what I've got mine on and it works fine.
    At worst you could also try
    File > Import
    and import your settings from Internet Explorer but you'd lose the data in Firefox unless you backed up your profile. :)
