fire wire
Discussion in 'Camcorders, Action Cams & Video Making Forum' started by jb 1, Jul 28, 2002.
  1. jb 1
    jb 1
    just wanna say thanks for all the advice but now i need some more.
    now i need fire wire card (which one) could you please state the full kit so i can go and get one' and is there any online shops you would recomend.
    thanks
  2. JefUK
    JefUK
    Mar 31, 2002
    448
    28
    +54
    Try http://www.dabs.com/
    Look for any IEEE1394 (firewire) card which is OHCI compatible (most are).
    Not much difference between any of them.
  3. Dubbing Mixer
    Dubbing Mixer
    Jan 27, 2002
    643
    By, and sometimes in, the sea
    You might want to check the chipset is the Texas instruments one. The NEC version has been known to give problems. If it helps, the D-Link card I purchased from Scan has the TI chipset and was less than £20.
  4. jb 1
    jb 1
    thanks for the info
