fire stick to AVR to splitter to projector.. to how?!?
davidaa
Hello I have a pioneer lx 59 and Sony 4k projector along with a fire stick 4k. But haven't been able to stream 4k because of he utterly pointless hccp 2 silliness. I can stream 4k fine using Plex. But this is really frustrating. I tried sticking the projector output to the splitter that connects to the projector, but I am getting a "computer says no" response complaining about HDCP 2.2..
I am using this splitter, which seems like a decent one.
Amazon product
Help would be much appreciated.
grahamlthompson
In memoriam
Amazon product
Assuming you will be using the projector or the TV but not both at the same time you need a 4K switch. A splitter will only work when connected to devices with identical resolution and audio capability.
This one has 5 inputs and one output. You only need two but will add some future proofing.
Amazon product
davidaa
Amazon product
I don't have a TV. Just a projector. So only one output. That does look good though. Thank you.
MarkBow
Do you mean you have the SC-LX59 AVR? If that's the correct AVR then you should have no HDCP problems.
davidaa
I do, but I think the problems are coming from the projector VPL-VW500ES. But it works a treat when using Plex, no 4k problems
MarkBow
So if you only have the firestick, AVR and projector then why use a splitter? Your chain should simply be the firestick plugged into one of the HDMI in ports on the AVR and then your projector plugged into the main HDMI Out on the AVR. Your projector does not have 'outputs' as it is simply a monitor so only has HDMI inputs to receive a feed.
davidaa
Because I don't get 4k from the fire stick that way. Just 1080HD. I can somehow still watch 4k stuff from Plex.. So odd and very annoying.
MaryWhitehouse
Doesn’t sound like HDCP. What source on the fire stick is it that you don’t get 4K from as it obviously can supply 4K as it is with plex.
MaryWhitehouse
Didn’t you get an answer here:
just a costly one unfortunately.
MarkBow
I would remove the splitter (most of them don't support DD+ anyway which is the main firestick audio codec) and as a test plug the firestick straight into the projector. Obviously there will be no sound but as long as the firestick is on auto resolution then it should display a 4k resolution. If you get a glorious 4k image then you need to make sure that your AVR is configured correctly and your HDMI cable from the AVR to the projector is 4K compliant and that the quality of the cable is suitable for the length required.
MarkBow
Well there you have it. MaryWhitehouse has kindly found the exact answer for you.
Your projector will never be able to display a protected 4K stream. Plex may well be looking like the stream is 4K and indeed report that the media being streamed is 4K but I would be confident in saying the actual pixel resolution synced with the projector is 1080p. The projector can tell you what pixel resolution it is displaying.
davidaa
Tried that. No cookie. I think the projector is the problem. I think it's hdcp 1.4 or something. It's all confusing nonsense.
MaryWhitehouse
It’s not confusing at all. However you seem to be talking about two different projectors and a blu ray in the other thread. So I’ll ask again what source on the Firestick is allowing 4K playback? Plex is possibly irrelevant as it suggests material that isn’t copy protected.
davidaa
I see so it must be about the material. That's why I can play youtube videos at 4k. I am not about to watch any 4k except for youtube and from Plex. There must be ways that don't cost £300 to get around this.. I hope.. So frustrating.
MaryWhitehouse
If you only play YouTube and plex and they both work what are you trying to get to work?
MaryWhitehouse
I'm trying to Amazon prime and my new 4k Netflix
Ok. So from the firestick Plex and YouTube play 4K but Prime and Netflix don’t. Both those apps only play HD? How do you know? Does the projector show you the different resolution?
davidaa
MaryWhitehouse
davidaa
Amazon tells me it won't play the 4k because of hdcp 2.2. Plex plays at the original quality, which is 4k and youtube I can change the quality to 4k.
MaryWhitehouse
Would have been helpful if you’d said you knew what the problem was first. In that case pay attention to the first answer you got. To play copyright material at 4K you’ll need something like what was offered on the other thread or a new projector.
Latest News
What's new on Netflix (UK) for October 2022
  • By Ian Collen
  • Published
Starzplay streaming service rebrands as Lionsgate+
  • By Andy Bassett
  • Published
JVC adds Filmmaker Mode to latest D-ILA projector firmware
  • By Andy Bassett
  • Published
Bowers & Wilkins launches Px8 headphone
  • By Andy Bassett
  • Published
Sky set to launch its plug-and-play Sky Stream solution
  • By Ian Collen
  • Published
