Pauliezx
Hello All,
Need some advice please on using an amazon fire stick. Basically, I can't work out how to get the sound to run through my yamaha 5.1 amp instead of the TV itself.
Current setup is a non smart Panasonic LED TV and and oldish yamaha 5.1 amp so the av gear is old and fire stick is new.
I currently run my ps4 audio into the amp via optical cable. The TV channel volume runs through the amp via scart cable, the amp does not have any hdmi or USB inputs.
The fire stick plugs into back of TV on a USB connection but that just gives audio to the TV speakers which are horrible. I don't really know how to get the firestick to run through the amp.
I know it's a case of using old tech with new tech but there's nothing actually wrong with the amp or TV so before I have to think about ditching them, is there any way to get it to work?
