Sparky83
Me and the wife would like to install a wood burner into our existing fire place, the issue i think i might have is that the fire place we have at the moment is in the upstairs of a house, (its been converted into 2 flats) so the chimney breast itself seems to house both the chimney for our fire and also the one for the fire in the room (and flat) below.
Has anybody even done this to a breast with 2 flues in it? they seems to be completly seperate from each other but i wouldnt want to start hacking away at it and then go through into the chimney?
Any advice is helpful,
This is our front room, you can see that the breast is bigger on one side than the other and i guess that its because the other flue is in this section?
