Jimmybonds007
Established Member
- Joined
- Jun 29, 2007
- Messages
- 485
- Reaction score
- 15
- Points
- 187
To be clear, it doesn't restart completely, it just stops video playback and goes to the home screen.
Current set up is this...
4k 'ready' HMDI cable from 4k UHD TV to Dolby Atmos Soundbar
Fire Cube using 48gps certified HDMI from Cube to Soundbar. Fire Cube stops playback and goes to Home Screen after about 5 minutes.
Now....
All these components were used in a Home Theatre set up (the only difference was the soundbar was connected to a projector via a different cable) and the Fire Cube was fine.
I know the answer is to eliminate each component individually but I'm being lazy in case someone on here sees this as a no brainer
Thank you any help.
Now....
Thank you any help.
