Finlux user manuals - where can I find one ?
Discussion in 'TVs' started by mortod, Aug 18, 2003.
  1. mortod
    mortod
    I've aquired second hand, and free, an old 28" 4:3 Finlux TV, but need a user manual for one. Any idea where I can get one ? The model number on the back is '5028524D1AN'. Have tried emailing Finlux but no response.
    Alternatively my specific questions are (perhaps someone with a similar model knows the answers):
    1. From the config menu there seems to be a choice of 4 AV inputs E1-E4, but with only one SCART socket on the back only E1 seems to work - what are E2-E4 for ?
    2. You are able to specify one of E1-E4 for VCR or SAT input, but I see no way of selecting VCR or SAT as an input option ? Selecting E1 as the input works fine though. I assume these are just labels, so that rather than showing E1 on the screen, VCR (say) is displayed - but I can't get that to work.
    3. Am I correct in assuming that this model does not support RGB input ?
    Thanks for any replies.
