Finlux TV - Progressive Scan ?
Discussion in 'General TV Discussions Forum' started by Badger, Jan 27, 2002.
  1. Badger
    Badger
    Jan 21, 2002
    259
    I've been looking at the Loewe's , but have decided to wait a while longer - to see if Prog scan arrived and/or the Aconda price came down a bit.
    Anyway, I was looking round to see if a grey import set would be an option and I came across this - I've no idea as to the quality/cost or if it even does progressive scan.
    ebay showed up one, which suggested an rrp of 1500 - but not much else. Are they just trying to flog 100Hz as PS, or have I misunderstood something.
    anyone got anything to say about it or any comments ?
    Phil
  2. encaser
    encaser
    Mar 15, 2001
    2,359
    116
    Suffolk/Essex
    +518
    The sites - both prima one you list, and Finlux home site - state prog scan. Interestingly they both also list VGA connection, but don't say anything about resolutions. Also no mention of RGB and no component input. Looks like they're going for a bit of an Aconda style. Never heard of them though.
    Perhaps some of the Swedish posters on here may have?
  3. brattle
    brattle
    Oct 12, 2001
    108
    16
    Bedford
    The site says the set has three scarts. Without component or RGB through seperate phonos or BNC, the set won't accept a prog scan input. The prog scan must be an internal deinterlacer.
    It also mentions VGA, but doesn't say anything about a VGA input which is wierd. Maybe this is added in a card like the Loewes.
  4. Badger
    Badger
    Jan 21, 2002
    259
    Thanks for the comments so far
    I've dug around a bit more and have found somewhere in the UK selling them - 1200 quid. This states 1 RGB input on the scarts which is the only downside in the spec so far so far - No component input. I'm note sure as to the quality of the information on this site though. It seems that the VGA input is standard.
    All of this (as noted above) suggests either
    a) the progressive is via the vga input
    or
    b) an internal line doubler
    Now would a doubler inside the tv not be as good as the doubler inside the a progressive player ? Wouldn't one inside the TV be better because all input could/would be PSed ?
    Onto the VGA question - a trawl of deja produces a few likely posts - but all of them are in one of the scandanavian languages, so no help there.
    I'll send a message to prima asking for more info
    Phil
  5. bob007
    bob007
    Had a Finlux TV about 8yrs ago it was called the sky design.....detachable side speakers and you could tilt the set back on it's stand it was well advanced for the time haven't heard of them in ages........replaced that with a Nordmende set...........i was well impressed with this one, the cabinet it stood on was a sub bass and on top of the cabinet was a video compartment, down the side of each speaker was a coloured strip which you could change depending on the decor of your room....how cool is that....! Nordmende use to do video projectors don't know if they still do......
  6. Badger
    Badger
    Jan 21, 2002
    259
    I've looked round the internet a little more and have had a reply from Prima, looks pretty good so far
    RGB Scarts
    Two of the scart sockets will take R.G.B Scart 1 & 2
    S-Video Scarts
    Scart 1 Only
    Composite
    Yes all Three Scarts are composite video compatible
    Component
    Scart 2 supports component signals
    Progressive Scan
    Unfortunately we can not clarify how the progressive scan is done
    VGA
    the resolution for the VGA input is
    640x480 at 60Hz
    440x400 at 70Hz
    640x350 at 70Hz
    720x400 at 70Hz
    All this still sounds reasonable but the set is pretty new so is only available from them directly at the moment - no details as to who has them. I'll post a link to this the PS forum to see if someone else can help.
    Phil
  7. Badger
    Badger
    Jan 21, 2002
    259
    anyone got any idea where I might find one of these to look at ?
    Phil
  8. SteveCac
    SteveCac
    Any luck in finding anyone Badger?
    I'm thinking about a Finlux, as from what I can make out in Swedish, they seem to rate them OK.
  9. Badger
    Badger
    Jan 21, 2002
    259
    nah - I just got an Aconda instead in the end as the only 2 sources were both questionable (ebay and a weird website) and the suppliers seemd to know very little
    Phil
  10. SteveCac
    SteveCac
    AFAIK Finlux have only just started selling to the UK again, and can't find anyone to translate swedish. I'm still interested because ideally I need a set to fit in a confined space and it does the job.
