Finding Tosh 210E RCE ok
Discussion in 'Blu-ray & DVD Players & Recorders' started by apul, Jan 8, 2003.
  1. apul
    apul
    Jan 8, 2003
    689
    Durham
    +19
    sorry if this has been asked before, but im new to this place.
    i need to know how to find out if my multi regoin toshiba 210E is able to play region1 RCE discs as im gonna get a new tv(ntsc playback) and some R1 RCE superbit dvds
    thanks.
  2. Chairman
    Chairman
    Dunno how you can find out without trying an RCE disk. Mine isn't. It won't play xXx. Dunno is that's a good or bad thing :D.
  3. apul
    apul
    Jan 8, 2003
    689
    Durham
    +19
    oh well, dont know many people into this sort of thing so i wont be able to borrow one. might just have to buy and try.
    havnt seen xXx, dont think i'll bother :rolleyes:
    thanks
  4. Jase
    Jase
    Mar 16, 2001
    9,470
    South Coast
    +894
    If the Tosh won´t play the Disc straight off, try the disc swap method. Load a non RCE R1 disc into the player, let it load up the Menu, then stop and put in the RCE disc. It should play, hopefully!
    Not all Superbit dvds are RCE either, despite some web sites saying that they are.
  5. bobbles
    bobbles
    I've got a tosh 210 multi it has played all my region 1 so far
    which releases are RCE anyway?
    I could tell you then if they work ok
  6. codling
    codling
    Jul 5, 2001
    427
    hartlepool
    +15
    anyone know the multi-region hack for this player.
    thanks carl
  7. apul
    apul
    Jan 8, 2003
    689
    Durham
    +19
    cool, thanks jase, hopefully that will work when i get a RCE disc.
    sorry codling, mine came region free when i bought it.
    have a look at www.play.com and select the region 1 site, it says if any discs are RCE.
    must go revise now...:(
  8. Chairman
    Chairman
    Cheers for that. Just tried it and it worked :)
  9. Jase
    Jase
    Mar 16, 2001
    9,470
    South Coast
    +894
    It´s where I get my discs from but they are wrong about the Superbit discs, not all are RCE (if any!). The only one that has caused a few problems is Panic Room (not on my players though).
  10. Jase
    Jase
    Mar 16, 2001
    9,470
    South Coast
    +894
    Hi Carl
    Most Toshibas need a Hardware modification of some sort, there are no hacks as such.
  11. codling
    codling
    Jul 5, 2001
    427
    hartlepool
    +15
    thanks jase/apul
    not to worry
    carl
  12. Rasczak
    Rasczak
    Apr 3, 2002
    21,224
    Warwick
    +2,268
    Yeah this is the same way as I get mine to play RCE disks. Never failed yet.
