finding nemo r2 ddex and dts query??
Discussion in 'Movie Forum' started by mick23, Jun 24, 2004.
  1. mick23
    mick23
    Mar 20, 2002
    801
    uk
    hi all having read in what-hifi finding nemo has ddex/dts 5.1 but the mag does not state r1/r2 r4 etc.
    i hired the 2 disk collecters edition english/hebrew vertion this shows dts /dd logo on rear of case.
    however running through set up it only appears to have dd5.1 option, does not show ex and does not appear to have dts vertion, can anyone clarify this .
    i am only running 5 speakers out of the 7 i have at the moment so not sure if that is affecting dvd read out on denon 3802
    dvd cover shows z1r d881232. thank you
  2. SimonO
    SimonO
    Nov 4, 2002
    3,293
    71
    Hertfordshire
    +64
    Don't think the DD is EX but I could be wrong... DTS is usually selected through the 'Language' menu...
  3. Family Guy
    Family Guy
    It's defo DD EX and DTS ES (matrix) and both versions are flagged...so your amp should pick them up automatically. IIRC, Denons are a real pain to set up to detect flags atutomatically...you'll have to ask one of the Denon experts mate in the amp forum...but take it from me, it is both flagged EX & ES...and simono is correct, go to the language menu, where you will be able to select dts...
  4. mick23
    mick23
    Mar 20, 2002
    801
    uk
    thanks simono/army bloke
    found the dts option under setup /language the display shows matrix 6.1 on denon will check to see if i have set flag in 3802 setup , to auto ,
    thanks all
  5. Crustyloafer
    Crustyloafer
    Sep 12, 2003
    9,566
    Edinburgh
    +1,266
    If you only have five speakers hooked up to the Denon amp then it will probably ignore the extra 6th channel and display the soundtrack as DD 5.1. My Pioneer does this and only displays 'DD EX' or 'DTS ES' if I have a 6.1 or 7.1 channel speakers setup attached to it.
