Hi All,
I have an old Denon AVR X2000.
I have a 5.1 set up - using Jamo A102HCS5
I have the other two speakers as part of a ZONE 2 set up.
ISSUE:
On reading the AVR X thread below, it suggests the following:
If you have a 7.1 Zone 2 model (1913 or higher/X2000 or higher) and want to send the "same" audio to more than just one zone/room, you can connect a multi zone impedance matching speaker selector (eg. 4 zone speaker selector) to the Surr Back/Amp Assign speaker posts.
SO...
In order to get better sound, I need to "impedance match" the speaker? Is that correct?
If so, I'm not really sure what to match. As the 5.1 speakers are satellites connected to a sub.
Advice greatly appreciated.
ISSUE:
- The sound from the Zone 2 speakers is poor.
- The speakers are on top of kitchen wall units
- I would like to buy better speakers for a richer more full sound.
- I will NOT be able to use a sub for these speakers
SO...
