Find a camera with the following specs:
Discussion in 'Photography Forums' started by Setenza, Jun 27, 2003.
  1. Setenza
    Setenza
    Jun 17, 2002
    3,349
    +226
    I am after a 3-4 megapixel camera with video with sound capcity, that also uses SD media.
    I'm currently looking at the Konica KD410Z but that stretches my budget.
    I was lokking at the Samsung Digimax V4 & Casio Exilim EX-Z3
    Are these any good or can anyone else recommend something.
    Budget £300 (excl VAT)
  2. minimad
    minimad
    Why SD media Xusia?
    I assume you have some already?
  3. Setenza
    Setenza
    Jun 17, 2002
    3,349
    +226
    Mainly as my laptop has a SD slot which does make life a lot easier.
    Still it doesn't have to be SD format.
  4. minimad
    minimad
    If it doesn't have to be SD, I would recommend the Canon A70 - you can get it for £240 saving enough to buy memory cards.
    I will have a look around and see what I can find :)
  5. minimad
    minimad
    Unfortunately it looks as if the SD Card is used by:
    Minolta, Pentax, Panasonic, Samsung, Casio and Kodak.
    I wouldn't recommend cameras by any of these companies in this price range.
    This is the range on the
    Jessops website as an example.
    I would go with the A70, Compact Flash and get a PCMCIA adapter for the laptop. You can get the adapter for around £30 I think.
    Collin
