Finally...
Discussion in 'AV Receivers & Amplifiers' started by papachumba, Oct 7, 2003.
  1. papachumba
    papachumba
    Oct 4, 2003
    79
    after weeks of careful data gathering I have made my choice as to what I'm about to get.
    Please read through and see if you would change anything...
    Pioneer PDP434HDE Plasma
    Pioneer VSX-AX5i AV Amplifier
    Arcam DV88 Plus DVD Video Player
    Arcam DiVA CD82T CD Player
    Arcam DiVA A85 Amp
    Arcam DiVA P85 Power Amp
    Project 1 Xpression Turntable
    Kef Q1 Speakers
    Kef Q9C Centre Speaker
    Kef Q2DS Surround Speakers
    Kef PSW3000 Sub Woofer
    :rotfl:
  2. Dimmy
    Dimmy
    Jan 15, 2003
    2,399
    39
    England
    Seems strange to have surround speakers worth significantly more than your front L/R speakers, but that's life I guess.
    Were I you I'd change the Q1s for some floorstanders.
    And I wouldn't buy an AX5i, since I've no use for the iLink (Buying a DV88+ and all).
    Buy an AX3 instead, save you around £210.
  3. ChrisNic
    ChrisNic
    May 11, 2003
    1,917
    63
    Thame
    +109
    Why are you buying a power amp aswell? To get an improved stereo performance you would need to buy an Arcam A85 (the intergrated amp) and plug the cd player and front pre-outs into there. The gains from having a good stereo power amp would be lost by having the pioneer as the preamp.
    I had the same idea a while back and I was quickly corrected.
  4. papachumba
    papachumba
    Oct 4, 2003
    79
    oooooooops my mistake i forgot to include the A85 in the list :suicide:
    My biggest concern is the AV amp and the speakers. I know Q1s are not as good as the rest of the surround speakers, but the problem that i am having is that the room is not that big in size and cramming all these speakers in there with some floorstanders might be a bit over the top. (room is 5m * 6m appx L shaped)
    Maybe q5s or q7s?
    Also the av amp - if i am to get speakers of this quality is Pioneer ok? I did hear only good things about it I admit, but then I was even considering the Arcam FMJ range for the AV amp. Of course this would mean dishing out for the FMJ Pre-Amp and these two are a tad too expensive. Also this would lead to having to change the speaker setup too and go for even higher quality speakers.
    I think I'll stick to whats on that list, and maybe go for q5s and q7s...
    Or what about the eggs 2005 + q1s for hifi? This would also give me a 7.1 setup and i could have my beautifull q1s and eggs not wasting a lot of space in the room.
    Basically, I want to get a perfect setup as I dont want to change components 2 years down the line. The setup would probably be moved too when I change apartments meaning they would go in a bigger room....
  5. wilber
    wilber
    Sep 29, 2002
    1,970
    +30
    4x Q1s rather than 2xQ1 & 2x2DS - I don't like the dipole speakers at all especially for multichannel music.
    Pioneer 2011 still available is supposedly a better amp
  6. ChrisNic
    ChrisNic
    May 11, 2003
    1,917
    63
    Thame
    +109
    Hang on, so your going to biamp your Q1's with £1300 of amplification???????? :rolleyes:
  7. gpa
    gpa
    I can recommend the q5's I have just bought 4 and a Q9 centre auditioned kef eggs but were very weak on the music side( not as tight and controlled,. hope this helps
  8. papachumba
    papachumba
    Oct 4, 2003
    79
    what about getting keff eggs with subwoofer for surround,
    then buying 2 hi-q extra speakers for hi-fi (i.e keff Q7s).
    With this setup ill be able to integrate a 7.1 system, have good quality hifi setup, together with those gorgeous eggs...
    i really would go for an all-out good speaker setup but im worried that they might be too intrusive in the room (30sq meters) and maybe the room is too small for the setup i mentioned in my first post.
    what are your thoughts?
  9. wilber
    wilber
    Sep 29, 2002
    1,970
    +30
    Nah that would mean using an egg as a centre with a pair of Q7s as fronts - just doesn't feel right to me.
    Forget Eggs and buy proper speakers - Qs look far classier (IMHO) are more versatile and are not something that will look "so 2003" like the Eggs will in a couple of years time.
  10. Hawklord
    Hawklord
    Feb 15, 2003
    3,530
    3
    Aldershot, Hampshire
    +294
    the q1's will be the weakest link in that set up imo. Surely to get the best from your amps (both integrated, power and av) you require something more suitable - especially if bi-amping?
    Some nice floorstanders will give you better results imo and using an egg as a center wouldn't give the same tonal match or range of larger cabinet speakers.
    just my 2p
  11. papachumba
    papachumba
    Oct 4, 2003
    79
    i see... thank for the help guys... very educational... :smoke:
