finally plasma on wall!!
suniil
Hi all,
Thanks for the help and ideas
Finally my plasma is inner plasterboard wall and rock solid!!
There were 2 layers of plasterboard (12 mm each) on both sides with timber studs 16/17 inchs apart. My screen is 37 inch
Steps
a. Got 2 MDF with size (20x35x18/20x35x6), fillers and wooden screws from B&Q
b. Another same size plasterboard (20x35x6)-->(thought of replacing 6 mm mdf with plasterboard for a better finish on surface and got the idea from DIY home cinema of this forum
c. Levelled 18mm mdf and fixed with 2 screws on to plasterboard and then cut the outline of MDF on plasterboard.
d. Removed the plasterboard and tried to fix 18 mm MDF and 6 mm plasterboard, but for some reason outer alignment was not correct and dropped the idea of 6 mm plasterboard
e. Glued both MDFs, drilled necessary holes and a big hole for the cables
f. Made a trial with 4 screws on frames and plasma hung on that.. seems to be rock solid and double checked by hanging 50 kg on a SINGLE screw.
g. Removed the panel, fixed with all the screws, pulled the cables and another string for pulling add-on cables, filled the gaps and painted (not applied finishing touches, will be changing the color in 1 months time)
h. And finally my plasma panel on wall!!
Alltogether took around 3-4 hours, but with good finish (This is my first DIY project) and my wife helped a bit to hold plasma, MDF etc
And finally queries(!!!)
a. From PC to VGA seems to be fine
b. I've tried with DVD(Panasonic SCHT520) to plasma (component to component) with quality cable from maplin and picture is grainy (??) Returned the cable
c. DVD->scart->JS converter->VGA to screen: no signal (i assume i've to activate scart output on DVD, but without seeing the menu how can i!!?, please help)
Thanks in Advance
N2P
Supersonic72
May I ask why the two sheets of MDF??
In total, theyre 24mm thick, (1" inch)...a pretty dense & solid combo??
suniil
B&Q have only 18 mm max. thickness. So i added 6 mm to make up 24 mm thickness, which perfectly matches with my plasterboard thickness (12x2)
Sorry for the confusion, actually the 6 mm plasterboard did'nt worked out properly and the same replaced with 6 mm MDF
N2P
tamthetim
new2plasma said:
Hi all,
Thanks in Advance
N2P
take it through to a portable or other tv and set it up via scart on the DVD menu, should get a funny coloured picture because its still outputing component.........but allows you to change it.
this is a prob i've come across a few times but the opposite way around...............as most DVD's are set to RGB when bought........hook them up via component..........................no picture.....................not fun if you don't have another TV to change it.
cheers, tam
tamthetim
doh..............or easy way hook in back up to plasma via component....................and change it then.......................pic should disappear :smashin:
Similar threads
Podcast: LG SN7CY Soundbar Review, Hisense 55U7Q, LG Nano90, Best of the Month, B+W Sigourney Weaver
