Finally!!!!!!!!!!! My HDE !!!!!!! (Pics inside)
Discussion in 'Plasma TVs Forum' started by Leerock, Jul 14, 2005.
  1. Leerock
    Leerock
    Dec 26, 2004
    273
    19
    I ve finally installed my 435hde and i must say i m blown away!!!!!!!
    It s just awesome.
    I can t even imagine a better picture than this.
    I ve taken some hd samples and downscaled them to pal and converted them to mpeg2 so i can play them with my pio 575.
    All I can say is WOW!!!
    I m forward to see how a true HD signal will look like.
    I don t have satellite yet but i m going to install one next week so I can t yet tell you how it performs with a highly compressed mpeg2 signal.
    Rf aerial signal (with poor reception, looks quite good, far better from what i expected.It s very crt like.
    I was only dissapointed with the blacks at first but after almost 100 hours of use they ve become deeper.
    I ve upload some pics of my setup which is not completely finished and i ll upload some more when the i get the furniture and the satellite finally installed.
    (Pics are not that fair coz they re highly compressed and downscaled)
    EDIT: My furniture finally arrived and i ve taken some more photos.
    Plus some RF pictures with poor reception.
  2. bix
    bix
    May 24, 2005
    356
    Manchester
    +7
    Wow! Amazing looking PQ. Still waiting till September for the 436.
    I assume thats a stud wall? Did you screw the bracket to the studs or through to the block using rawl bolts?
    Also, how did you get the cables past any horizontal studs?
  3. yellowpostit
    yellowpostit
    Jun 27, 2005
    177
    19
    Nottingham
    It's interesting you say the RF pq is crt-like. There's been a lot of people saying the rf/freeview/sky pq is not that good on pio's, almost putting me off. Is it really not that bad?
    oh, whats the diff between hde's and xde' s, apart from the digi tuner?
  4. ikon66
    ikon66
    Mar 22, 2005
    449
    Tyne & Wear
    +5
    i've got the xde and the PQ on all is easily as good, if not better, than my 100htz crt, the difference between the fde and xde is the digi tuner and a vga input for a pc I think
    just an ob leerock, but did you not prefer the speakers under the panel?
  5. gizlaroc
    gizlaroc
    Jul 26, 2001
    9,175
    Norwich
    +795
    Looks good mate!
    Seems very high compared with where you speakers are? Any reason?
  6. bix
    bix
    May 24, 2005
    356
    Manchester
    +7
    I'm suprised you even bothered with the speakers considering you have a 5.1 setup
  7. GeorgePk
    GeorgePk
    Mar 12, 2005
    75
    Nicosia
    +4
    Nice setup there Leerock. Its something I visualize for my new house
    Any suggestion and/or reccomentations on burring cables.
    What to do and what NOT to do?
  8. Leerock
    Leerock
    Dec 26, 2004
    273
    19
    Hi guys.
    I m glad you liked my setup, and thanks for your opinions.
    yellowpostit: I think rf picture isn t just "not bad". I think it s great.Much better from what i expected after reading these forums.
    The difference between them is only the digital tuner as far as i know.
    ikon66: i prefer the speakers on the sides.
    I ve put them both ways and i liked them on the sides better.
    Have you got them on the bottom?
    Any pic?
    gizlaroc: perforce the furniture is going to be too tall to cover the wall plugs that my stupid electrician have put too high.(55 cm from the floor).
    and i don t want the tv to be too close to the furniture.
    But you are right, I may move it a bit lower.
    bix:I think the speakers are needful for normal tv viewing.
    You don t have to power on the amp every time you sit to hear the news or some other bull**** :)
    GeorgePk the most difficult thing if you are building a new house is to find the right spots for your surround speakers and your tv so you can pass some pipes uder the floor and through the wall.
    I must say I was a bit lucky on this.
    I think it s not a big deal as it looks like.
  9. ikon66
    ikon66
    Mar 22, 2005
    449
    Tyne & Wear
    +5
    I have mine under to save the width in a small room, as you may be able to see on my avatar. I would have gone for the black air ones as they fit in with design better, but each to their own.
    And I agree about speakers with a 5.1 system, a lot of extra switching for basic tv especially in the am before work :D
  10. ash
    ash
    Jun 9, 2005
    11,221
    +395
    Nice, how much did it cost you and from wre?
  11. smargi
    smargi
    May 22, 2005
    62
    how did you config the plasma what are the setting...?
  12. Anderzander
    Anderzander
    Boy have you generated some interest! :-D
    It's really nice to read your post though - and your pictures look fantastic!
    Mine arrives from John Lewis on thursday and I can't wait!
    woo hoo!
  13. poshngoldenball
    poshngoldenball
    Very nice set up however......don't see the fridge with beers therein :rotfl:
  14. Leerock
    Leerock
    Dec 26, 2004
    273
    19
    :laugh: :laugh: :laugh:
    It s in the kitchen
  15. Leerock
    Leerock
    Dec 26, 2004
    273
    19
    I ve got contrast and brightness a bit low for the first 200 hours.
    My settings are:
    Aerial:
    Contrast 18
    Brightness 0
    Colour -1
    Sharpness +1
    All enhancements to low except dre to mid which i think it improves contrast a lot.
    DVD:
    Contrast 22
    Brightness 0
    Colour -2
    Sharpness +1
    All enhancements to off except dre to mid.( I love dre :) )
  16. SILVERBACK
    SILVERBACK
    Aug 13, 2001
    3,836
    71
    birkenhead
    +74
    mate that is a lovely setup,not just the AV side either its just a really nice living area :thumbsup:
  17. smiffy333
    smiffy333
    May 10, 2005
    1,827
    48
    +73
    Very nice Leerock very similiar to what I'm planning to do soon hopefully.
    I've been having difficulty finding furniture but yours looks just right , where did you get it from and was it expensive.
  18. Leerock
    Leerock
    Dec 26, 2004
    273
    19
    Hi smiffy
    My furniture is custom made.
    I ve made the design in photoshop :) and gave it to the cabinetmaker.
    It was very difficult to find a store-bought cabinet that would suit my needs
