Finally got my plasma.
Discussion in 'Plasma TVs Forum' started by waddell28, Jun 13, 2004.
  1. waddell28
    waddell28
    :thumbsup:
    Got a Panny 42TH-PE30 from JL.
    TBH I can't smile wide enough!
    I've turned down the contrast & brightness to under halfway along the bars, as recommended by other posters.
    I've got an Avia HC disk, can I use it right away or do it give the TV time to run in?
    Also, I can't play a DVD in prog scan mode. I've got the component inputs hooked up, the dvd player set to ps mode but the picture is all over the place. What am I doing wrong?
  2. waddell28
    waddell28
    Anyone enlighten me?
  3. Claus
    Claus
    I guess you have a player that doesn't output progressive PAL signals. What player do you have? Try out a region 1 disc to check.
    C
  4. waddell28
    waddell28
    I tried it with the Tevion 1100 (Cheap player I know!).
    Tried an R1 disk but no good.
  5. hammerman
    hammerman
    you say youve changed the output from your dvd player to ps......but have you changed the input on the screen itself to component?(at least thats what I have to do on my 434.......)
  6. waddell28
    waddell28
    Not sure how you do that.
    Doesn't mention it in the manual, just says accepts component input.
  7. hammerman
    hammerman
    maybe I did not explain myself too well,so I'll use my 434 as an example.........
    Input 3 has several connections:
    scart,component,hdmi........depending on which I use,I have to go into the menu on input 3 and manually choose the best option...
    ie....RGB,S-Video,composite,component or HDMI....
    in my case its set to HDMI as I have an 868,but it wont work properly if I select the wrong option....... :)
