Finally Finished
Discussion in 'Members DIY Home Cinema Showcases' started by Movieman, Feb 27, 2005.
  1. Movieman
    Movieman
    Jul 4, 2004
    550
    Wirral
    +21
    Just finished putting the finishing touches to cinema room (converted 3/4 of a double garage). Moved all the kit from the living room and here are the results. Weeks of fun now calibrating all the kit to suit the new surroundings.
    Enjoy
    Movieman
    (Lexicon RV8, Infocus 5700, Denon 2910, Rega Planet CD, B&W Nautilus 805, B&W Nautilus HTM2, B&W DS6, B&W CDM1, Rel Strata 5, Sky +, XBox 360)
  2. loftfuton
    loftfuton
    Feb 4, 2003
    93
    BELFAST
    Nice job Movieman. What are those DVD storage units in image 3 ?
    Loftfuton
  3. Kazman
    Kazman
    Jan 14, 2004
    5,264
    Luton, Bedfordshire
    +136
    Excellent setup :) :smashin:
    That RV8 looks well tasty :) Good size room too, well done!!
  4. Movieman
    Movieman
    Jul 4, 2004
    550
    Wirral
    +21
    Thay are a product called Disc Gear (http://www.romdex.co.uk/html/discgear.html), you basicly put your discs inside, compile a list of the titles using software provided, insert the list into the front of the unit, then when you want a disc you slide the selector to the disc number, lift the lid and it lifts the disc out for you. They make them to hold 20, 40, 80, 100 Disc.Movieman
  5. Stew
    Stew
    Feb 1, 2003
    52
    Very nice, I don't know what that lexicon thing does but it looks very flash.
    I'm wondering what paint you used, I've been after a paint for my bedroom cinema, other than the usual grey, might be just the ticket.
    Finally where'd you get that alien thing, looks huge!
  6. Movieman
    Movieman
    Jul 4, 2004
    550
    Wirral
    +21
    StewThanks, the Lexicon thing is an AV receiver for watching movies in Dolby Digital and other formats. The paint is called Opulence from a shop called Wilkinsons. I got the alien from The Gadget Shop and it stands about 18 inches and is made of nuts, bolts and scrap metal.
  7. wawr
    wawr
    Nov 3, 2002
    154
    wales
    +9
    Fantastic set up you have there..bet it sounds as good as it looks..well done !!!!
  8. Thunder
    Thunder
    Feb 26, 2004
    1,763
    41
    +14
    Nice set up mate!, have a look at mine and tell me what you think?
  9. Movieman
    Movieman
    Jul 4, 2004
    550
    Wirral
    +21
    Thanks Thunder, just looked at your's and its a vey nice job.
  10. mrcolobus
    mrcolobus
    Sep 20, 2004
    39
    11
    Rochester
    Very nice indeed, I wish I had a spare room........ and £10,000 spare. Have you got the High Def pack for the X Box, I bet Panzer Dragoon Orta would look the dogs twitcher on a screen like that.
  11. Movieman
    Movieman
    Jul 4, 2004
    550
    Wirral
    +21
    Thanks Mrcolobus, Just orderd the Hi def pack for the Xbox, l'll let you know how it looks when it comes.
  12. mrcolobus
    mrcolobus
    Sep 20, 2004
    39
    11
    Rochester
    ...and your XBox is already chipped?
  13. Movieman
    Movieman
    Jul 4, 2004
    550
    Wirral
    +21
    No it's not, I've been woundering weather it would be worth while or not? and what benifits would I get?
  14. michael.redfern
    michael.redfern
    Oct 14, 2003
    859
    Manchester
    +91
    Movieman, Where did you get the wooden stand that the Lexi is in? I'm after a stand that can take 3 components wide and it look ideal.
  15. Movieman
    Movieman
    Jul 4, 2004
    550
    Wirral
    +21
    Michael, It's from Ikea.
  16. mrcolobus
    mrcolobus
    Sep 20, 2004
    39
    11
    Rochester
    Although the high def pack will give you component outputs, it needs to think the xbox is NTSC if you want progressive output. You'll get 480p out of most, if not all of you PAL games.
    Mail me if you want more info, or have a nose at xbox-scene.com for all the info you'll ever need.
  17. Chaos Star
    Chaos Star
    Jan 9, 2003
    1,264
    38
    Scotland
    +18
    Nice wall colour Movieman, think it is idebtical to the Milaniplex :)
  18. Movieman
    Movieman
    Jul 4, 2004
    550
    Wirral
    +21
    Ive just realised that my post was well out of date so i have Just made some photo changes to my 1st post, with new kit, Panasonic PT AE700 projector, Denon 2910 and XBox 360
  19. kdog
    kdog
    Mar 6, 2006
    360
    Ayrshire
    +62
    Very nice indeed:thumbsup:
    Looks well done and very inviting...............1 sugar and milk please:D
  20. Dynaudio Desire
    Dynaudio Desire
    Dec 8, 2005
    1,293
    Bury st. edmunds
    +57
    :eek: :eek: :eek: :eek:
    That looks..........irresistable.....no must....resist!
    I envy you with your 804's! :smashin:
    But what a great room.........astonishing!!
  21. Movieman
    Movieman
    Jul 4, 2004
    550
    Wirral
    +21
    Thanks guys, I'm pleased with it. I have just had SKY HD installed to day in the living room, I also had cables run into the cinema room so I can take the sky box in watch the England match tomorrow in high def. Ill let you know how it looks. cheers once again.
  22. IVOLIC
    IVOLIC
    Jan 26, 2004
    142
    Croatia
    +7
    The room is very nice (love the alien sculpt).
    But your equipment ROCKS!!!! :thumbsup: :thumbsup:
    Very jealous of your system m8...
  23. John 1987
    John 1987
    May 25, 2005
    1,180
    +221
    Can't believe I've never left a comment in here before. Amazing set-up, truly amazing, I love the red colour.
  24. Movieman
    Movieman
    Jul 4, 2004
    550
    Wirral
    +21
    Thanks Guy's
  25. Gadget Daddy
    Gadget Daddy
    Feb 19, 2005
    3,281
    83
    Stockton on Tees
    +185
    quality mate, you really have got me thinking should I do the same to my garage:devil: , did you do the conversion yourself?
  26. Movieman
    Movieman
    Jul 4, 2004
    550
    Wirral
    +21
    Cheers PeteB_2000
    yes I did do it myself except for the plastering.
  27. CFS
    CFS
    Dec 2, 2005
    491
    +55
    Very nice, bet that lexicon is amazing. Does the rug help alot in dampening the sound? I've got laminate flooring as well but currently no rug or much in the way of soft furnishings, just wondering how much of a difference it would make if I put one down?
  28. Movieman
    Movieman
    Jul 4, 2004
    550
    Wirral
    +21
    Thanks CFS, the rug made a huge difference it made everything sound tighter and with a smoother bass. i also put the dark brown cloth at the front which also helped with the front sound stage.
  29. m0v1em4n
    m0v1em4n
    Jul 1, 2001
    819
    Derby
    +48
    Very nice :thumbsup:
    steve
  30. metropolis
    metropolis
    Mar 5, 2006
    1,288
    liverpool
    +201
    it looks fantastic, well done.
    ps. is that you standing at the back of the room ?
