Finally Bit The Bullet!
Discussion in 'Subwoofers' started by SBanga, Jul 18, 2005.
  1. SBanga
    SBanga
    Mar 23, 2005
    2,026
    Leeds, Yorksha
    +6
    After three months of careful deliberation on what to spend my £400 - £500 on, I finally decided on a sub! I discussed on this forum my thoughts of buying a Velodyne CHT-12R, a Sony SA-WX900, a SVS PB10-ISD and a BK Monolith. And the chosen one I went for is...........
    a Paradigm Servo 15!! It was up on ebay and I couldn't resist. I've read up on it (both on here and elsewhere) and not seen a bad word said about it. Also, I am buying a known entity rather than having only a few reviews to go by, as the Sony and BK do. I know it isn't quite in the same league as Steve.EX's four :eek: or Chris' two, but, hopefully I'll be happy with my upgrade from my now popped Paradigm PS-1000. I'm picking it up on Thursday so I'll let you guys know how pleased I am then!
    A big thank you to everyone who contributed in my buying decision!!! :smashin:
  2. 30CenturyMan
    30CenturyMan
    Dec 3, 2004
    927
    46
    +117
    Good choice. :)
  3. SBanga
    SBanga
    Mar 23, 2005
    2,026
    Leeds, Yorksha
    +6
    I've been playing with my new friend for three days solid now and I can't find any chinks in its armour. Yes, I have only heard a few subwoofers in my time but the Servo is still jaw droppingly good compared to my old PS1000 (I didn't expect such a big difference). Even at very low volumes, it sounds deep and impressive. At high volumes, with music and movies, the thing is just gut wrenching. Its the first time I've heard a house room properly pressurised with bass and there's still plenty of headroom!!
    The only slight problem I do have is a bit of hum and some random pops. Is this just a dirty power supply and I need to buy a mains conditioner? Or does it have anything to do with the X-30 control box? Anyone with similar experiences???
  4. SBanga
    SBanga
    Mar 23, 2005
    2,026
    Leeds, Yorksha
    +6
  5. SBanga
    SBanga
    Mar 23, 2005
    2,026
    Leeds, Yorksha
    +6
    Okay, I've managed to pin point the "random pops" to switches elsewhere in the house being turned on and off. So I'm guessing I do have a dodgy power supply and the hum may be caused by this too. The thing is, I never had this problem with my old sub plugged into the same socket. Now, would I be best off buying a proper mains conditioner or would a general purpose spike protector from Argos or the like suffice? I don't want to spend loads of money but the spikes are annoying when listening at low volumes!!
  6. eviljohn2
    eviljohn2
    Jul 8, 2002
    7,545
    Near London.
    +208
    I find that the Belkin gold series work very well and aren't too expensive. :)
  7. SBanga
    SBanga
    Mar 23, 2005
    2,026
    Leeds, Yorksha
    +6
    They seem reasonable but I don't need seven sockets! Any good ones with less sockets?? Only the sub's going to be connected so other sockets will be going to waste.
    Or what about this??? http://www.hifibitz.co.uk/product.asp?id=4222
  8. Dfour
    Dfour
    Jan 19, 2004
    4,091
    71
    Bracknell
    +86
  9. SBanga
    SBanga
    Mar 23, 2005
    2,026
    Leeds, Yorksha
    +6
    My only problem is that my amp and tv are a fair distance away from the sub so I can't plug everything into one hub, and I obviously can't run the sub power cable alongside the phono cable. Then again, if the Belkin solved the problem, I could probably get over 7 plugs being wasted!!
    EDIT : Just seen the six socket version on amazon for £40 including delivery. Good buy?? I'm still a bit unsure if this'll solve my problem. Don't wanna be stuck with a £40 extension socket!!!
  10. Dfour
    Dfour
    Jan 19, 2004
    4,091
    71
    Bracknell
    +86
    I run my power cable (home made) to my sub right next to my sub coax cable (mark grant made) and dont find it makes any difference. I would recommend plugging everything in to the hub and then make a cabel of your own to run from it to the sub.
    The gain from the extension is worth the inconvience of running a long cable to your sub. :D
  11. SBanga
    SBanga
    Mar 23, 2005
    2,026
    Leeds, Yorksha
    +6
    OK, I'm gonna order the Belkin tommorrow and use it next to the sub for the time being. When I get some more money (Servo's drained me!!) I'll buy a custom screened sub and power cable. Should do the trick!!
  12. Dfour
    Dfour
    Jan 19, 2004
    4,091
    71
    Bracknell
    +86
    Look at Mark Grants sub cables in the cable power buy section. They are top quality for :beer: money.
    ALso look in the diy cable section and you will find a few ways of makeing your own power cabel for peanuts compared to buying one. My 2 metre cable cost me under £10 to make with plugs, in fact the left orientated plug for the sub cost the most:eek:
