Finalizing DVD - RAM discs? How is it done?
Discussion in 'Blu-ray & DVD Players & Recorders' started by Big Wally, Aug 31, 2005.
  1. Big Wally
    Big Wally
    Aug 31, 2005
    I have a Panasonic E 85 DVD recorder with hard disc, which records onto DVD-RAM also. I want to play the - RAM disc on another player, (Pioneer)but the specification says that the -RAM disc must be finalized before it can be played. I have searched the Panasonic manual, but find no reference to finalizing a DVD-RAM disc. Can the disc be finalized? Help, please!!
  2. narke
    narke
    Oct 30, 2003
    114
    Leeds
    +3
    I can't speak for the Panasonic but I know that you can't finalize RAM disc's on a Toshiba (XS34). I tried but the machine fired up a window stating that it was not supported on that type of disc. I checked the manual and the only references to finalizing disc's is for R/RW. Maybe the Panasonic is the same.
  3. Big Wally
    Big Wally
    Aug 31, 2005
    Thanks for the comment on your experience. I am beginning to think that DVD - RAM discs cannot be finalized. Perhaps I should stick to one recording mode!
  4. bowler
    bowler
    Jun 8, 2003
    223
    I play RAM discs on a separate DVD player without any finalizing being done.
  5. HMHB
    HMHB
    Nov 11, 2001
    25,556
    Nottinghamshire
    +3,884
    RAM discs don't need finalizing - just like a hard disc doesn't need finalizing. To be able to play a RAM disc in another machine that player has to be able to read DVD-RAM discs.
  6. Zebadiah Twine
    Zebadiah Twine
    Jul 8, 2005
    56
    The only reason I can see for using RAM-Discs is the Timeslip function, if you want to record things to keep or to play in other DVD players(apart from the few which support RAM-Discs)you should stick to +or- R or RW depending on which your machine supports.
  7. Steve.J.Davies
    Steve.J.Davies
    Nov 14, 2004
    2,995
    83
    +201
    DVD-RAM is reusable. As such 'finalise' is out of context.
  8. alan8477
    alan8477
    Dec 17, 2001
    574
    Pershore
    +5
    -RW is reusable, but it still requires finalising for use on other players. I am sure that DVD RAM only continues to appear because some early adopters have RAM discs. They are virually valueless on a machine that has HD and -RW. Or am I missing something?
  9. ROYOLD
    ROYOLD
    Jul 5, 2005
    3,898
    103
    Royton, Oldham. Lancs.
    +297
  10. mobilenvidia
    mobilenvidia
    Aug 30, 2005
    14
    Once you've used the DVD-RAM technology you'll not look back.
    There is only one setback, they are quite costly, but the usefulness outweighs this.
    No need to finalise, can edit the files easily, you can remove files and the disk actually gains free space (DVD+- don't) due to non linear disk usage.
    Proper Timeshifting.
    DVD-RAM in a cartridge will keep for ages, as it's competely proptected ideal for daily recording and handeling.
    On my Panny EH60 it doesn't convert the movies to 4:3 P&S while dubbing as it does with DVD +- R(w)
    DVD-RAM is the media that DVDR should have used from the start.
    If you really need to have older player support, DVD-RAM drives will record to either DVD-R or +R or both.
