Finalising disc on another machine?
Discussion in 'Blu-ray & DVD Players & Recorders' started by cataman, Jun 30, 2005.
  1. cataman
    cataman
    I recently returned a Toshiba RD-XS34 DVD recorder back to the retailer due to a hardware fault, however, I forgot to finalise a few discs before sending the unit back.
    My question is whether I'm up the creek with this or is there a way to finalise the discs on a PC or another machine?
    Any help appreciated!
    Dave.
  2. musukebba
    musukebba
    Jan 11, 2005
    689
    +16
    One trick that certainly worked with +R discs is to write an additional small dummy text file, which will often enable finalisation routines on DVD writing apps such as Nero. The text file should not interfere with the video content playback.
  3. cataman
    cataman
    Thanks, I'll give it a try.
  4. eddyad
    eddyad
    Jan 5, 2003
    940
    Hampshire
    +9
    If you get another Toshiba you should be able to finalise on that. Or maybe you know someone who has one.
