Final Speaker Question
H
Hyb
I am going for the Mission M72 package but I can go for the original one with the M7DS rears for £265 or one for £249 with M70 rears.
Any opinions as to the best package?
Andywilliams
hi hyb
go for the m7ds these cost twice as much as the m70s they also sound alot better believe me ive got them.
cheers gonzo.:D
H
Hyb
Thanks I will :)
I'm also getting a Marantz SR4200 which is coming this week.
What cables will I need to buy to get it all to work?
Andywilliams
hi hyb
you will need speaker wire qed silver anniversary for your front three speakers qed micro for your rears[£4.00metre and £1.25 metre] from hifi junkies.A coaxial cable to connect your dvd to the amp around£20-£30 and you will need interconnects phono to phono for your tv digi box and 2 channel from dvd to amp for playing cds so at least three lots. Superfi do decent interconnects for£9.99 they are made by profigold and should cost £15 . I assume youve already got a scart to scart for your dvd to tv.
hope this helps gonzo.;)
H
Hyb
This maybe a stupid question but, when ordering speaker cable, I obviously measure 1 length from the speaker back to the amp and do this for the 5 different speakers. So say the total is 18 metres, when I get this cable it will be in one 18 metre length right?
Do I have to buy seperate plugs and connect them myself, or do they all have bare wire connections (Marantz 4200 and Mission M72's)
:blush:
Jase
Depends where you buy from, you can either get one long run of cable and cut it and terminate the ends yourself (or leave them as bare wire) or specify cut lengths with or without terminated ends (usually costs extra).
Ian J
I would suggest that Silver Anniversary at £4 per metre is overkill for budget speakers. That's what I use for my M&K's
H
Hyb
I intend on upgrading later on so I think £4 per metre is fine.
One last question, if I connect the DVD -> TV via scart and DVD -> AV via coaxial do I need a second coaxial to connect the AV -> TV, or is not required to go from AV -> TV?
Huggy
Not an expert, but I had the same kit, and your plan will work. No need for the TV - AV, it will work fine.
Similar threads
