This is the most expensive forum I've ever been a member of
A few days in the Speakers forum and I ended up with a pair of Acoustic Energy AE1 MK111's + Atacama R724 Reference stands.
A couple more days in the amp section and I saw myself with a Musical Fidelity A5 Integrated.
My plan is actually to pick up an MF A5 pre and power and eventually replace the integrated, but that's dependant on the second hand market. Source will be an Arcam DV89 for now..
Anyway, regarding this setup, my questions are:
How much should I spend on interconnects?
How much should I spend on speaker wire and should I bi-wire?
How much should I spend on banana plugs and are they all the same 'fit'?
Does anybody have any suggestions for cable and/or plugs?
Thanking you!
Thanking you!
