Final Fantasy R1 problems
Discussion in 'Movie Forum' started by DrScary, Oct 23, 2001.
  1. DrScary
    DrScary
    Anyone had any problems with this DVD yet.
    After a while the picture keeps freezing but the sound continues. It starts doing it towards the end of the movie in different places.
  2. gargoyle
    gargoyle
    Nov 8, 2000
    629
    birmingham
    +21
    When I watched it for the first time on saturday, there was no problem.However, watching it tonight, the film froze briefly 3 times in the first hour of the film - it was played on a samsung 709.
  3. Koosnaff
    Koosnaff
    Jun 1, 2001
    79
    9
    Kent, UK
    I have had no such problems - Wharfedale 750s
  4. LV426
    LV426
    Administrator Staff Member
    Jul 14, 2000
    12,840
    Somewhere in South Yorkshire
    +5,067
    Watched it once, Pioneer 737 - no problems
  5. Jenz
    Jenz
    Wathed it thrice (?) on Arcam DV27, Sony 725 and Pioneer DVDRom 106. Played fine.
  6. KEV.G.
    KEV.G.
    HI GUYS,
    THIS IS A FIRST FOR ME SO BEAR WITH US,
    I HAVE ALSO HAD PROBLEMS WITH THE REGION 1 EDITION OF FINAL FANTASY, PLAYED ON A MINATO DVD PLAYER IN R1 MODE THE IMAGE IS VERY JERKY AND THEN PLAYED ON A SAMSUNG 709 THE DISC LOCKED UP ON SEVERAL OCCASIONS. MAYBE IT HAS SOMETHING TO DO WITH THE AMOUNT OF CGI IN THE MOVIE, THIS IS POSSIBLY ONE OF THE PROBLEMS LOWER END DVD PLAYERS WILL START TO SUFFER FROM. STILL DISPITE THIS IT WAS STILL AN EXTREMELY ENJOYABLE MOVIE AND I SHOULD ADD SOUNDED AMAZING!!
    ALL THE BEST, KEEP UP THE GOOD WORK,
    YOURS
    KEV GREENHALGH.:D
  7. LV426
    LV426
    Jul 14, 2000
    12,840
    +5,067
    I can't see how the CGI content could possibly have any effect on how the player plays the disc. The player isn't required to "interpret" CGI any differently to any other film. Actually I'd expect you to see SMOOTHER movement than on a regular NTSC DVD.
    I understand that it has been mastered directly from the Computer original - rather than telecine'd from celluloid. I suspect it has been properly converted at 30fps - and not at 24fps with pulldown. This has the beneficial effect of making movement much smoother than normal for NTSC discs.
    Your player doesn't perchance, convert NTSC to true PAL/625/50, does it? If yes, this may be the cause. If you have some switch or menu item which would tell the player to output either true NTSC/525/60 or pseudo-pal (PAL/525/60) - try doing that and playing the film again.
    Otherwise, it sounds like a player problem. Unless anyone else can throw any light......
    (By the way - typing in CAPITALS is considered the on-line equivalent of shouting. For your future reference........)
  8. Force Field
    Force Field
    Watched it last night for the first time on my Tosh SD2109, and apart from the usual messing about because it is an RCE disc, it played perfectly well. Picture and sound crystal clear - no probs at all. :)
  9. othello
    othello
    Oct 9, 2001
    147
    16
    england
    my pana rv60 played it like a dream.no probs at all.filmnot as good as i hoped though:( hope shreks better.should be here any time.:)
