Final Fantasy R1 Does it play on modified machines?
Discussion in 'Movie Forum' started by ddb2k, Dec 31, 2001.
  1. ddb2k
    ddb2k
    R1 version of Final Fantasy - Spirits within presents Region Code Warnig that the DVD will not operate on modified DVD players. The cyber home N212 is programmed as a multi region machine. Other R1 discs have worked so far. Does any one have a suggested way forward?
  2. Zone
    Zone
    Jun 24, 2001
    6,813
    Barnsley
    +2,573
    Cant answer your specific question , but why not buy the region 2 version, no difference what so ever according to
    Rewind
    Goodluck
    Si
  3. Reiner
    Reiner
    Jul 16, 2000
    3,316
    61
    Germany
    +13
    Sounds like a RCE (Region Code Enhancement) to me and obviously your player doesn't like it. This can happen, depending on the hack/modification of the player, i.e. how it has been made multiregion compatible.
    The only option I see is to set the player manually to a specific region (R1 in this case) if your player allows so. Then the DVD will think it's a R1 player and not a R0 player. Still no guarantee that it will work though ... but I wish you good luck!
  4. mysteriousjimmy
    mysteriousjimmy
    Disc 1 of the R1 Final Fantasy is RCE
  5. ddb2k
    ddb2k
    Thanks for the advice. This disc is RCE and will pplay when the machine is set to R!
