Final Countdown
Discussion in 'Movie Forum' started by maggi, Jan 23, 2003.
  1. maggi
    maggi
    I bought this DVD when it came out some time ago.
    View it once then okay,but last night it froze in chapter 6 and the picture was all messed up.
    I was thinking if any of you have seen the same thing on yours.
    The DVD i´m refering to is that cheap Hollywood DVD.
  2. Rambo John J
    Rambo John J
    Aug 11, 2000
    3,731
    Hanoi Hilton
    +961
    I've played mine 2 or 3 times and it's been OK.
    Have you used a lens cleaner on your player (just in case it's that)?
  3. maggi
    maggi
    I tried several discs and this is the only one,maybe it´s time to clean the lens
    thanks for the advise John j
  4. Rambo John J
    Rambo John J
    Aug 11, 2000
    3,731
    Hanoi Hilton
    +961
    I hope it works.
    I had similar problems with a few discs and had to resort to going inside the machine to clean the lens properly by hand rather than using a cleaner disc. Sometimes a cleaner disc can't get all the muck off and it plays havoc with your playback. I hope you can sort it out without having to do something quite so drastic (not that it was a difficult job to do). They all played fine afterwards though.
