Final choices Canon g3 Oly 5050
Discussion in 'Photography Forums' started by dustyboy, Aug 1, 2003.
  1. dustyboy
    dustyboy
    Help me make a decision please,any reason to spend 459 on 5050 as opposed to 399 on G3.Cameras seem to make you spend twice your budget don't you think.
  2. Matt F
    Matt F
    Jul 18, 2000
    900
    Chester, UK
    +4
    Olympus is £430 according to uk.pricerunner.com.
    However, I'd take the Canon at £399. It's a close thing but I seem to remember the Olympus having a few chromatic (purple fringing) issues. On top of that I believe the Canon's layout/controls are more logical. The C5050 has more pixels though - swings and round-abouts.
    Check both on www.dpreview.com.
    Then go and try each out and see which you prefer the feel of.
    To be honest, you won't go wrong with either.
    One final thought - if you feel you are spending too much then why not check out the Olympus C4000 at £280 ish - it's a fine camera. Similarly, if you don't mind a slower lens then what about the Canon S45 at £330 or so?
    Matt.
  3. dustyboy
    dustyboy
    Matt, you are without doubt,a very proper geezer,thanks.The thing about spending too much money is because I am completely ignorant about this field.Even if you gave me the best cam in world I will only be able to take snaps.Thing is , like many before I am sure,I don't want to waste money on camera I will outgrow.And when I look at the two cameras mentioned,I want to touch them,and hold them,they are just so tempting.Cheers mate.
  4. TommyVecetti
    TommyVecetti
    Feb 10, 2003
    1,763
    uk
    +93
    G3. I prefer canon. I've got the G2 which I'm more than happy with.
  5. CarlB
    CarlB
    Jan 8, 2001
    1,287
    Cambridgeshire
    +219
    G3 is a great camera, I got one when I outgrew my point-and-click Kodak 4900.
    You won't outgrow the G3, it's fantastic and at current prices a real bargain.
  6. dustyboy
    dustyboy
    Picked the c5050 in the end,felt nicer in the hand,got it for 459 quid with the extra 256 of xd mem.Not bad eh.Thx all.
