Filters
Discussion in 'Photography Forums' started by SGH42, Aug 5, 2003.
  1. SGH42
    SGH42
    Arethere any digital cameras that you can use Cokin or any other filters on ?
  2. woody67
    woody67
    Nov 11, 2002
    634
    Birmingham, UK
    +13
    You can buy adapters that fit to the tripod screw, or clip on - you can then use normal slide in filters.
    However, except for perhaps a polarizer or ND filter, you should consider just capturing the shot at the best quality possible, and applying effects on computer with Photoshop or similar.
    You will then not "spoil" the shot with an effect that you can not remove later.
    woody
  3. m@rk
    m@rk
    Jan 3, 2002
    1,212
    83
    Lincolnshire
    +360
    I was given a full set of Cokin filters (about 40 of them) last year and they work well with my little Canon A40.
    Whilst some of them are usable (the star filters for example) the graduation ones etc are a waste of time.
    First you need to get around the auto white balance (which tried and compensates for the filter) and even then, because the lense is quite small, the effect is not great.
    Option 2 is (as said above) to apply the effect later on in Photoshop. Indeed you can even get a set of PS plugins to match the Cokin filter range
  4. SGH42
    SGH42
    Any idea where I could get the adaptors that would screw into the tripod thread ?
  5. m@rk
    m@rk
    Jan 3, 2002
    1,212
    83
    Lincolnshire
    +360
