Filters
Discussion in 'Photography Forums' started by russellsnr, Jul 8, 2003.
  1. russellsnr
    russellsnr
    Hi, Can someone please advise me as to the filters i should be using (if any) on my Mavica FD75.
    If i should use filters can they be the same as you would use on an SLR or do i need specials ?:confused:
    Also if i can use SLR filters can i buy a stepup ring ?
  2. MarkE19
    MarkE19
    Aug 10, 2002
    17,131
    Rainham Essex
    +2,393
    I have had a look at the camera and none of the specs list this cam as having a filter thread on the lens, therefore I don't think you can attach filters. If you can then they will almost certainly be specific for that camera (that means expensive :rolleyes: ).
    Mark.
